09-21-2011 01:59 PM - edited 03-04-2019 01:41 PM
We need to configure a L2L VPN to another site for the purpose of doing secure backups to a hosted backup service. Because they handle multiple clients, we can't do a non-NAT VPN to them, as they can't sort out all the different private IP ranges from everyone, so we have to use the external IP address.
We've set it up so that there is a global pool for a one of the available outside IP addresses.
There is an network object group containing the internal IP addresses of the servers to be backed up.
There is a NAT rule that uses an ACL for connections from the backed-up servers' inside IP addresses to the destination VPN target IP.
Tunnels and crypto maps are fine, confirmed matches of both the encryption setup and the preshared key.
IKE phase 1 completes fine.
However, it gets dumped after that, because the other end claims that our network isn't can't find a match in their tunnels list. When they look at the logs, our side is presenting 0.0.0.0 as our network, rather than the NAT'd external IP address.
I can confirm that the NATing itself works. Packet trace shows it NATing, xlate table shows the nat'd IP, and even browsing out to What is My IP shows NAT'd address.
Ideas?
Excerpts from sanitized config below: ASA 8.2(3)
(Please ignore minor errors in IP addresses. They're probably typos due to sanitizing...)
object-group network BackedupServersOutside
network-object host 99.99.99.60
object-group network BackedupServersInside
network-object host 10.0.0.1
network-object host 10.0.0.2
network-object host 10.0.0.3
object-group network BackupTargets
network-object host 192.168.90.154
network-object host 192.168.90.149
access-list Servers_NAT extended permit ip object-group BackedupServersInside any
access-list VPN_to_Backups extended permit ip any object-group BackupTargets
global (Outside) 5 99.99.99.60
global (Outside) 10 interface
nat (Inside) 0 access-list no_nat
nat (Inside) 5 access-list Servers_NAT
nat (Inside) 10 access-list nat
crypto ipsec transform-set remote_transform esp-3des esp-md5-hmac
crypto ipsec transform-set BackupTransform esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map remote_map 90 set transform-set remote_transform
crypto dynamic-map remote_map 90 set reverse-route
crypto map crypto_map 10 match address VPN_to_Backups
crypto map crypto_map 10 set peer 65.65.65.100
crypto map crypto_map 10 set transform-set BackupTransform
crypto map crypto_map 90 ipsec-isakmp dynamic remote_map
crypto map crypto_map interface Outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal 30
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
nac-settings value DfltGrpPolicy-nac-framework-create
webvpn
svc keepalive none
svc dpd-interval client none
svc dpd-interval gateway none
svc compression deflate
customization value DfltCustomization
tunnel-group 65.65.65.100 type ipsec-l2l
tunnel-group 65.65.65.100 ipsec-attributes
pre-shared-key *****
Excerpt from Crypto ISAKMP debugging:
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE Initiator: New Phase 1, Intf Equipment, IKE Peer 65.65.65.100 local Proxy Address 0.0.0.0, remote Proxy Address 192.168.90.154, Crypto map (crypto_map)
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing ISAKMP SA payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing NAT-Traversal VID ver 02 payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing NAT-Traversal VID ver 03 payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing NAT-Traversal VID ver RFC payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing Fragmentation VID + extended capabilities payload
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 204
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 128
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, processing SA payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Oakley proposal is acceptable
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, processing VID payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Received NAT-Traversal ver 02 VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Received Fragmentation VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, IKE Peer included IKE fragmentation capability flags: Main Mode: True Aggressive Mode: True
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing ke payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing nonce payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing Cisco Unity VID payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing xauth V6 VID payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Send IOS VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing VID payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, constructing NAT-Discovery payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, computing NAT Discovery hash
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (130) + NAT-D (130) + NONE (0) total length : 296
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (130) + NAT-D (130) + NONE (0) total length : 296
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, processing ke payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, processing ISA_KE payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, processing nonce payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Received Cisco Unity client VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Received xauth V6 VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000409)
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, processing NAT-Discovery payload
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, Connection landed on tunnel_group 65.65.65.100
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, Generating keys for Initiator...
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing ID payload
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing hash payload
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, Computing hash for ISAKMP
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing dpd vid payload
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 114
Sep 20 16:27:09 [IKEv1]: Group = 65.65.65.100, IP = 65.65.65.100, Automatic NAT Detection Status: Remote end is NOT behind a NAT device This end is NOT behind a NAT device
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, processing ID payload
Sep 20 16:27:09 [IKEv1 DECODE]: Group = 65.65.65.100, IP = 65.65.65.100, ID_IPV4_ADDR ID received
65.65.65.100
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, processing hash payload
Sep 20 16:27:09 [IKEv1 DEBUG]: IP = 65.65.65.100, Processing IOS keep alive payload: proposal=32767/32767 sec.
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, processing VID payload
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, Received DPD VID
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, Oakley begin quick mode
Sep 20 16:27:09 [IKEv1 DECODE]: Group = 65.65.65.100, IP = 65.65.65.100, IKE Initiator starting QM: msg id = 93344904
Sep 20 16:27:09 [IKEv1]: Group = 65.65.65.100, IP = 65.65.65.100, PHASE 1 COMPLETED
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, Keep-alive type for this connection: DPD
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, Starting P1 rekey timer: 82080 seconds.
IPSEC: New embryonic SA created @ 0xD8C5C8F0,
SCB: 0xD8C97F60,
Direction: inbound
SPI : 0x5385D238
Session ID: 0x038DE000
VPIF num : 0x00000001
Tunnel type: l2l
Protocol : esp
Lifetime : 240 seconds
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, IKE got SPI from key engine: SPI = 0x5385d238
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, oakley constucting quick mode
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing blank hash payload
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing IPSec SA payload
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing IPSec nonce payload
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing proxy ID
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, Transmitting Proxy Id:
Local subnet: 0.0.0.0 mask 0.0.0.0 Protocol 0 Port 0
Remote host: 192.168.90.154 Protocol 0 Port 0
Sep 20 16:27:09 [IKEv1 DECODE]: Group = 65.65.65.100, IP = 65.65.65.100, IKE Initiator sending Initial Contact
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing qm hash payload
Sep 20 16:27:09 [IKEv1 DECODE]: Group = 65.65.65.100, IP = 65.65.65.100, IKE Initiator sending 1st QM pkt: msg id = 93344904
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE SENDING Message (msgid=93344904) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 188
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE RECEIVED Message (msgid=aa21e4e3) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, processing delete
Sep 20 16:27:09 [IKEv1]: Group = 65.65.65.100, IP = 65.65.65.100, Connection terminated for peer 65.65.65.100. Reason: Peer Terminate Remote Proxy N/A, Local Proxy N/A
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, sending delete/delete with reason message
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, constructing IPSec delete payload
Sep 20 16:27:09 [IKEv1]: IP = 65.65.65.100, IKE_DECODE SENDING Message (msgid=49a40e5a) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 64
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, IKE Deleting SA: Remote Proxy 192.168.90.154, Local Proxy 0.0.0.0
Sep 20 16:27:09 [IKEv1]: Group = 65.65.65.100, IP = 65.65.65.100, Removing peer from correlator table failed, no match!
Sep 20 16:27:09 [IKEv1 DEBUG]: Group = 65.65.65.100, IP = 65.65.65.100, IKE SA MM:3796ec4f terminating: flags 0x0100c822, refcnt 0, tuncnt 0
Sep 20 16:27:09 [IKEv1]: Group = 65.65.65.100, IP = 65.65.65.100, Session is being torn down. Reason: User Requested
Sep 20 16:27:09 [IKEv1]: Ignoring msg to mark SA with dsID 59629568 dead because SA deleted
Sep 20 16:27:09 [IKEv1 DEBUG]: Pitcher: received key delete msg, spi 0x5385d238
I'm assuming that I shuold be seeing the "Local Proxy" as 99.99.99.60 and not 0.0.0.0 but how to fix it?
Solved! Go to Solution.
09-21-2011 02:15 PM
Dan
change your crypto map acl VPN_to_Backups from -
to
access-list VPN_to_Backups permit ip object-group BackedupServersOutside object-group BackupTargets
Jon
09-21-2011 02:04 PM
p.s. - Also ignore references to "Equipment" in the debug, those were not sanitized to "Inside". =)
09-21-2011 02:15 PM
Dan
to
Jon
09-21-2011 02:21 PM
Well I'll be a *&$%^#@$^@#$^236ing duck.
Thanks. =)
