Event manager stuck at cli command and aborts
Hello All,
I hope you are doing fine, I have an issue with my event manager created on an operational Cisco router
I raised a CISCO TAC and the assigned engineer advised me to check here in the EEM community issues and raise my query so i came to you.
The issue : I have applet manager with event track and action reset crypto and interfaces, the APPLET work as expected some time and give a status successful and stuck some time at shut interfaces without unshutiing them back and give us abort status applet and that caused internet isolation to our customer because the interfaces that were shut was our GW to the internet
Below is the Chassis/IOS type and version with event manager config and status of applets
Chassis: ISR4331/K9
IOS: isr4300-universalk9.03.16.04c.S.155-3.S4c-ext.SPA.bin"
+++++++++++++event manager config is below
Event manager applet1 is when track 101 is down we need to clear crypto then reset tunnels 1 and 2 then add a sys log "MONITOR-TRACK101-DOWN"
Evenet manager applet 2 is when track 102 is down we need to shut tunnel 2 then add a sys log "MONITOR-TRACK102-DOWN"
event manager session cli username "mshaltou"
event manager applet MONITOR-TRACK101-DOWN
 event track 101 state down
 action 10 cli command "enable"
 action 11 cli command "conf t"
 action 12 cli command "clear crypto iskamp"
 action 20 cli command "int tunnel 1"
 action 21 cli command "shut"
 action 22 wait 2
 action 23 cli command "no shut"
 action 30 cli command "int tunnel 2"
 action 31 cli command "shut"
 action 32 wait 2
 action 33 cli command "no shut"
 action 40 syslog msg "MONITOR-TRACK101-DOWN"
event manager applet MONITOR-TRACK102-DOWN
 event track 102 state down
 action 32 wait 2
 action 40 syslog msg "MONITOR-TRACK102-DOWN"
+++++++++++Show event manager
pmil3736#     sh event manager policy registered
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    applet    user    track               Off   Wed May 31 14:25:16 2017  MONITOR-TRACK101-DOWN
 maxrun 20.000
 action 22 wait 2
 action 32 wait 2
2    applet    user    track               Off   Wed May 31 14:25:27 2017  MONITOR-TRACK102-DOWN
 maxrun 20.000
 action 32 wait 2
pmil3736#sh event manager version
Embedded Event Manager Version 4.00
Component Versions:
eem: (rel9)1.2.12
eem-gold: (rel1)1.0.2
eem-call-home: (rel2)1.0.5
Event Detectors:
Name                Version   Node        Type
application         01.00     node0/0     RP
rf                  01.00     node0/0     RP
syslog              01.00     node0/0     RP
neighbor-discovery  01.00     node0/0     RP
generic             01.00     node0/0     RP
track               01.00     node0/0     RP
routing             02.00     node0/0     RP
resource            01.00     node0/0     RP
cli                 01.00     node0/0     RP
counter             01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
none                01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-object         01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
timer               01.00     node0/0     RP
test                01.00     node0/0     RP
config              01.00     node0/0     RP
env                 01.00     node0/0     RP
ds                  01.00     node0/0     RP
crash               01.00     node0/0     RP
gold                01.00     node0/0     RP
rpc                 01.00     node0/0     RP
pmil3736#
pmil3736#sh event MANAger history events detailed
No.  Job Id Proc Status   Time of Event            Event Type        Name
1    379    Actv success  Sun Aug27 01:13:13 2017  track             applet: MONITOR-TRACK102-DOWN
2    380    Actv success  Sun Aug27 01:31:14 2017  track             applet: MONITOR-TRACK102-DOWN
3    381    Actv success  Thu Aug31 12:49:13 2017  track             applet: MONITOR-TRACK102-DOWN
4    382    Actv success  Fri Sep 1 01:41:10 2017  track             applet: MONITOR-TRACK102-DOWN
5    383    Actv success  Fri Sep 1 02:59:12 2017  track             applet: MONITOR-TRACK102-DOWN
6    384    Actv abort    Fri Sep 1 03:15:12 2017  track             applet: MONITOR-TRACK102-DOWN >>>>>>>>>>>>> aborted
7    385    Actv success  Fri Sep 1 09:59:11 2017  track             applet: MONITOR-TRACK102-DOWN
8    386    Actv abort    Fri Sep 1 10:02:11 2017  track             applet: MONITOR-TRACK102-DOWN >>>>>>>>>>>>>> aborted
9    387    Actv success  Mon Sep 4 10:12:13 2017  track             applet: MONITOR-TRACK102-DOWN
10   388    Actv abort    Mon Sep 4 12:10:11 2017  track             applet: MONITOR-TRACK102-DOWN >>>>>>>>> aborted
+++++++++++++++++++++My SYS Log output showing Behavior of the EVENT manager and displaying when interface was shut and kept in the shut status is below
pmil3736.controlnet.equant.net|2017-08-20 17:52:01|TRACK|6|STATE|201 list boolean and Down -> Up|
pmil3736.controlnet.equant.net|2017-08-20 17:52:01|TRACK|6|STATE|101 ip sla 101 reachability Down -> Up|
pmil3736.controlnet.equant.net|2017-08-20 17:51:20|LINEPROTO|5|UPDOWN|Line protocol on Interface Tunnel2, changed state to up| >>>>>>>>>>>>>>>> action taken by event manager on tu2 to unshut
pmil3736.controlnet.equant.net|2017-08-20 17:51:20|LINK|5|CHANGED|Interface Tunnel2, changed state to administratively down| >>>>>>>>>>>>>>>>>>>>>> action taken by event manager on tu2
pmil3736.controlnet.equant.net|2017-08-20 17:51:20|LINK|5|CHANGED|Interface Tunnel1, changed state to administratively down| >>>>>>>>>>>>>>>>>>>>>> action taken by event manager on tu1 where Tunnel 1 stuck at admin down !!!!!!!!!!!!!!!********************
pmil3736.controlnet.equant.net|2017-08-20 17:51:14|HA_EM|6|LOG|MONITOR-TRACK101-DOWN: MONITOR-TRACK101-DOWN|  ++++++ SYSLOG Added by event manager
pmil3736.controlnet.equant.net|2017-08-20 17:51:13|LINK|3|UPDOWN|Interface Tunnel1, changed state to up|
pmil3736.controlnet.equant.net|2017-08-20 17:51:06|TRACK|6|STATE|101 ip sla 101 reachability Up -> Down|
pmil3736.controlnet.equant.net|2017-08-20 17:48:06|TRACK|6|STATE|202 list boolean and Down -> Up|
pmil3736.controlnet.equant.net|2017-08-20 17:48:06|TRACK|6|STATE|102 ip sla 102 reachability Down -> Up|
pmil3736.controlnet.equant.net|2017-08-20 17:48:01|TRACK|6|STATE|201 list boolean and Down -> Up|
pmil3736.controlnet.equant.net|2017-08-20 17:48:01|TRACK|6|STATE|101 ip sla 101 reachability Down -> Up|
pmil3736.controlnet.equant.net|2017-08-20 17:47:25|LINEPROTO|5|UPDOWN|Line protocol on Interface Tunnel2, changed state to up|>>>>>>>>>>>>>>>> action taken by event manager on tu1 to unshut
pmil3736.controlnet.equant.net|2017-08-20 17:47:21|LINEPROTO|5|UPDOWN|Line protocol on Interface Tunnel1, changed state to up|>>>>>>>>>>>>>>>> action taken by event manager on tu2 to unshut
pmil3736.controlnet.equant.net|2017-08-20 17:47:17|LINK|3|UPDOWN|Interface Tunnel2, changed state to up|>>>>>>>>>>>>>>>> action taken by event manager on tu2 to unshut
pmil3736.controlnet.equant.net|2017-08-20 17:47:16|HA_EM|6|LOG|MONITOR-TRACK102-DOWN: MONITOR-TRACK102-DOWN| ++++++ SYSLOG Added by event manager
pmil3736.controlnet.equant.net|2017-08-20 17:47:15|HA_EM|6|LOG|MONITOR-TRACK101-DOWN: MONITOR-TRACK101-DOWN| ++++++ SYSLOG Added by event manager
pmil3736.controlnet.equant.net|2017-08-20 17:47:14|LINK|5|CHANGED|Interface Tunnel2, changed state to administratively down| >>>>>>>>>>>>>>>> action taken by event manager on tu2 to shut
pmil3736.controlnet.equant.net|2017-08-20 17:47:13|LINK|3|UPDOWN|Interface Tunnel1, changed state to up|>>>>>>>>>>>>>>>> action taken by event manager on tu1 to unshut
pmil3736.controlnet.equant.net|2017-08-20 17:47:10|LINK|5|CHANGED|Interface Tunnel1, changed state to administratively down|>>>>>>>>>>>>>>>> action taken by event manager on tu1 to shut
pmil3736.controlnet.equant.net|2017-08-20 17:47:10|TRACK|6|STATE|102 ip sla 102 reachability Up -> Down|
pmil3736.controlnet.equant.net|2017-08-20 17:47:06|TRACK|6|STATE|101 ip sla 101 reachability Up -> Down|
pmil3736.controlnet.equant.net|2017-08-20 17:47:01|IKEV2|5|SA_UP|SA UP|
Thanks a lot and appreciate to hear back from you guys the suggestions and if we need to adjust the config what would be the best practice or if we have to increase the maxrun time or the wait time between each script's line what should it be like ?
Mai Shaltout
Leo Laohoo
Duplicate thread.
Kindly post all responses into the main thread (HERE).
