exact mtu to enable mpls over gre tunnel
dipak.timsina
hi,
I've a scenario like below
pc ------ rtr1 <--- p2p link ---> rtr2 ------ pc
rtr1 and rtr2 doesn't support interface mtu size more than 1500 in their wan interface.
I've configured mpls over gre but can't pass through clear 1500bytes packet. i can only pass through 1464bytes packet size live on wire.
how should i adjust mtu to pass through clear 1500bytes packet with or without fragmentation.
dipak
Frederic Vanderbecq
to allow 1500 byte packets to be sent across the tunnel, you will either have to:
1) increase the MTU of the WAN interfaces (apparently not possible here)
2) You can also try to configure "tunnel path-mtu-discovery" under the tunnel interfaces and let them find the best MTU based on the path they cross or decrease the mpls mtu. Though, if you the tunnel MTU is decreased, that means fragmentation will occur. If applications are using the df-bit, you will then need to clear the df-bit for each packets entering the router.
Which router/module/interface are you using here ?
both routers are 7206 vxr (npe300) with all fe interfaces using c7200-p-mz.122-31.SB16.bin
router didn't allow me to configure mpls mtu on tunnel interface. "tunnel path-mtu-discovery" is enabled on tunnel.
