Exclude addresses from encryption
elise.lucas
Hello
I've configured encryption between site A and site B as followed:
On site A, this my configuration. As you can see, all traffic going through the interface Gi0/2/1 is encrypted.
crypto ipsec transform-set MyProfile-Trans esp-aes 256 esp-sha-hmac
crypto ipsec profile MyProfile
     set transform-set MyProfile-Trans
interface Tunnel110
description *** Tunnel to SITE B ***
bandwidth 1000000
ip address 171.0.103.1 255.255.255.252
tunnel source GigabitEthernet0/2/1
tunnel mode ipsec ipv4
tunnel destination 171.0.98.146
tunnel protection ipsec profile MyProfile
interface GigabitEthernet0/2/1
description *** Interface to SITE B ***
ip address 171.0.98.41 255.255.255.252
ip ospf hello-interval 5
I would like now to exclude some addresses from this tunnel. What is the best way to do so?
Thank you
Elise
You can use policy-based-routing (PBR) to route some traffic a different way:
http://www.cisco.com/en/US/partner/products/ps6599/products_white_paper09186a00800a4409.shtml#wp14033
http://www.cisco.com/en/US/partner/docs/ios/12_2/ip/configuration/guide/1cfindep.html#wp1001398
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Hello
Thank you for your answer.
Is there no other possibility than a PBR?
I've seen something like:
crypto ipsec profile name
match acl-name transform-set transform-set-name
But this "match" command is not accepted by my router: do you know why?
Thank you
Where have you seen that statement? I'm not aware of that command in that place.
But anyhow it would be the wrong place to achieve your goal.
What addresses do you want to exclude? Specific sources or specific destination-addresses.
For sources, there is only PBR. For destination-addresses you can tweak your routing-protocol to anounce more specific host-routes on the preferred way.
