Expect script show run int g0/0.x
sas2k3001
I'm looking for except script
That will able to run command show run int g0/0.x on 4,094 vlan's
ThanksRouting
Giuseppe Larosa
Hello @sas2k3001 ,
no router can support 4,094 VLAN based subinterfaces on the same physical interface ( at least at branch/enterprise level)
However, you can collect the output of
show ip interface brief  | inc gi0/0\.
inside the script
in this way  you will find a list of all defined subinterfaces the \.  tells that you are looking for literal . character and to avoid to consider it a special character in a regular expression.
Once you have the list of defined subinterfaces you can run for each of them
show run int gi0/0.<value>
Hope to help
Giuseppe
Jon Marshall
As suggested in your other thread you could use Python and Netmiko.
The following is a very basic script that would do what you want (it has no error checking etc) -
#!/home/netadmin/ntc/bin/python
import re
from netmiko import ConnectHandler
swp = ConnectHandler(device_type='cisco_ios',
                     host='172.30.2.2',
                     username='<your username>',
                     password='<your password>',
                     secret='<enable password>' )
swp.enable()
results = swp.send_command('sh run')
swp.disconnect()
for intf in re.findall(r'(interface Gigabit0/0\.\d+[^!]+)', results, re.DOTALL):
    print(intf)
You would obviously need to set the IP,  the username and the passwords.
Jon
Dan Frey
Another option is to use the tcl shell to dynamically discover all the interfaces associated with Gig0/0.XXXX and run the show command by pasting this into exec level of the router cli.
term length 0
tclsh
set lines [exec "sh ip int brief | inc GigabitEthernet0/0"]
    foreach line [split $lines "\n"] {
        if [regexp {(GigabitEthernet0\/0\.[0-9]+)} $line match interface ] {
            show interface $interface
