IP nat inside source command with : match-in-vrf
croue
What is the explanation of the option " match-in-vrf" in the command ip nat inside source?
Because nothing is explain on the CCO.
router(config)#ip nat inside source list TEST pool POOL_TEST vrf VRF_TEST ?
match-in-vrf Match incoming vrf
overload Overload an address translation
<cr>
aghaznavi
Level 5
Level 5
The match-in-vrf keyword is missing from the ip nat inside source command, and the ip nat inside source command is not accepted at all in interface-configuration mode. This symptom is observed on a Cisco 7200 series that runs Cisco IOS interim Release 12.4(11.6a) or interim Release 12.4(12.03)T but may also affect other routers.
csco10387876
the match in vrf allow you to have the same translation in two distinct vrf
so that you can have something like
ip nat inside source a.a.a.a b.b.b.b vrf a match-in-vrf
ip nat inside source a.a.a.a b.b.b.b vrf b match-in-vrf
but this feature is, as far as I know, only working for a vrf-lite config.
knagavol
Javier Teliz
The Match-in-VRF Support for NAT feature supports Network Address Translation (NAT) of packets that communicate between two hosts within the same VPN routing and forwarding (VRF) instance. In intra-VPN NAT, both the local and global address spaces for end hosts are isolated to their respective VPNs, and as a result, the translated addresses for the hosts overlap each other. The Match-in-VRF Support for NAT feature helps separate the address space for translated addresses among VPNs.
In summary:
! The match-in-vrf keyword enables NAT inside and outside traffic in the same VRF.
! The match-in-VRF Support for NAT feature helps separate the address space for translated addresses among VPNs.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-2/nat-xe-2-book/iadnat-match-vrf.html
