Explain the benefits and drawbacks of static routing
Benefits:
- it is simple to implement.
- it consumes no bandwidth with updates.
- if there is only one path to the destination the static route will use the optimum path.
- if you want to be in charge of how things work in your network then static routes are the ultimate expression on this.
Drawbacks:
- dynamic routes are more complex
- static routes require manual effort.
-  the more routes exist the more manual effort is required
- if there is more than one path to the destination the static route may use a suboptimal path.
- if the path used by the static route stops working it will require manual effort to configure a different path.
- dynamic routes choose the optimal path and dynamically change in reaction to changes in the network.
Rick
Rick
here are some good explanations:
http://www.dummies.com/programming/networking/cisco/pros-and-cons-of-static-routing/
http://www.ciscopress.com/articles/article.asp?p=2180210&seqNum=5
Benefits:
Drawbacks:
Rick
Rick
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Rick has already noted the major points.  However, did want to emphasis, the major issue, whether static routing might be used, is often the complexity of the network's topology.  Static routing doesn't "scale".  I.e. static routing is often unmanageable for all but very small and/or "simple" topologies.
However, static routing and dynamic routing are often used together where their pros and cons might be used to offset each other.
For example, an "edge" router, with only locally directly connected networks, might only have a static default for everything non-local.  The "other side" WAN router, would have static routes for the edge site's routes, but it also injects those static routes into its dynamic routing protocol.
The forgoing is commonly used with sites that connect to an ISP.  The edge site doesn't run a dynamic routing protocol with the ISP, but the ISP does advertise the edge's network(s).
One more benefit in addition to Ricks and Josephs great list:
  • can't be manipulated/exploited from the outside and forced to use additional resources.
    This is sometimes relevant when routing is done on security-devices.
