Explanation of show interface serial command
bapatsubodh
Where on Cisco.com can I get detailed explaination of all parameters shown in the output of show interface command...
Searched lots but could not get on Cisco.com
Thankx in advance.
Subodh
6 Replies 6
devang_etcom
Level 7
Level 7
hi,
you will find it in following link...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_command_reference_chapter09186a008010f99c.html#wp1020497
remember to rate this post if it helps
regards
Devang
devang_etcom
Level 7
Level 7
hi subodh,
i think this will be much better for you...
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1915.htm
please rate this post if it helps
regards
Devang
Good finding!
Vlad
hey VLAD
you thanks dear...
hey its really helps you or just comment...
regards
Devang
well, actually I'm working on a All ethernet network these days, but I used to work on a provider, so serial lines are not that a mistery to me.
But I believe the link will be really helpful to the "owner" of the topic. This is why I've rated 5.0
Vlad
in addition to the other posts, you might also want to have a look at this link:
Understanding the SHOW INTERFACE SERIAL stats
http://www.tek-tips.com/faqs.cfm?fid=1310
GNT
