Ext ACL
alaeldien
hello
iwant to config extended ACL to the rt to block any incoming packets from internet i.e only port like FTP, SFTP , must be opend for inbound and outbound communication, can any one deal in this issue.
thanks
srimural
Configure access-list allowing whatever you require. configure access-group in and out.
Thanks and Regards,
Srinath Muralidharan
Cable&Wireless
hello Srinath
thank you for your immediate response, could you possibly give sample configs assuming the same case.
thank you
ip access-list extended BLOCK-IN
permit tcp any any eq ftp
permit tcp any any eq sftp
ip access-list extended BLOCK-OUT
interface x/y
ip access-group BLOCK-IN in
ip access-group BLOCK-OUT out
This is just a sample and need to be modified.
Even you can add security with host ip mentioned, i mean the ftp or sftp server.The port number of sftp is tcp 115 and for ftp is tcp 20 and 21
Thanks and Regards,
Cable&Wireless
+91 99809 30364
