Extend card for cisco 2610 router
sip_james
Hi all:
I have 3 three years old 2610 router,which include 1 ethernet port and 2 wic slot.Now I want to add another ethernet port,but can't find any moudule can fit my needs.
Anybody has a idear?
Thank you in advanded.
lgijssel
Level 9
Level 9
I looked up the overview of supported modules:
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_data_sheet0900aecd800fa5be.html
It looks like you little options besides the NM-1E.
Leo
The link again, so that you can open it without CCO account:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet0900aecd800fa5be.html
leonvd79
Level 4
Level 4
Consider buying a 2611 or even better a 2621. There is a one port ethernet WIC (WIC-1ENET=) which is listed for 1700 series platform only.
To find available modules for your router platform consult this webpage:
Solution Finder for Modular Routers
http://www.cisco.com/pcgi-bin/finder/msbsearch.pl
