Extended ACL not work on cisco 1941
horboyz123
I apply extended ACL on my router cisco 1941, but it didn't work. So I tried to apply standard ACL, it's work. I'm not sure about my cisco 1941 IOS is support extended ACL. My cisco IOS is
Cisco CISCO1941/K9
c1900-universalk9-mz.SPA.151-4.M1.bin
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
Below is extended and standard ACL that I use to test apply on cisco 1941 gigabit ethernet interface
interface GigabitEthernet0/0
ip address 172.29.1.2 255.255.255.0
ip access-group 7 in
ip flow ingress
duplex auto
speed auto
access-list 7 permit any
Result: All traffic can pass this interface
Standard IP access list 7
    10 permit any (688 matches)
ip access-group 100 in
ip flow ingress
duplex auto
speed auto
access-list 100 permit ip any any
Result: All traffic never pass this interface
Extended IP access list 100
    10 permit ip any any
How can I solve this problem ?? Is it IOS bug or limit feature on hardware.
This certainly seems to be buggy behavior. Access list 100 applied on the interface with ip access-group 100 in should work and the ping should be successful. I am surprised that it is not working. I do have a few suggestions:
- if this router is covered by a maintenance agreement  then opening a case with Cisco TAC would be a good thing to do.
- I wonder if some other access list number might work. If you tried, for example access-list 150 permit ip any any and apply it to the interface does it make any difference.
- c1900-universalk9-mz.SPA.151-4.M1.bin has been improved and updated. Can you try c1900-universalk9-mz.SPA.151-4.M4.bin and see if it works better?
Rick
Rick
20 Replies 20
Richard Burts
I am not clear what the issue here is. But I know that 1941 routers with the IPBase license should support extended access lists on the Gig0/0 interface.
Please re-configure the interface with the extended access list. Then attempt to send some traffic. Then do these commands and post the output:
show access-list
show ip interface Gig0/0
Rick
Rick
Hi Rick.
     I tried to do with your advice configure and send ping traffic to this interface, so extended access-list still not work. Please see result below.
Standard access-list result
ip flow ingress
duplex auto
speed auto
xxx#ping 172.29.1.2
Sending 5, 100-byte ICMP Echos to 172.29.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
xxx#sho access-lists 7
    10 permit any (203 matches)
xxxn#sho ip interface gigabitEthernet 0/0
GigabitEthernet0/0 is up, line protocol is up
  Internet address is 172.29.1.2/24
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.5 224.0.0.6
  Outgoing access list is not set
  Inbound  access list is 7
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: Ingress-NetFlow, Access List, MCI Check
  Output features: Post-Ingress-NetFlow
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
Extended Access-list result
ip flow ingress
duplex auto
speed auto
xxx#ping 172.29.1.2
xxx#sho access-lists 100
xxx#sho ip int g0/0
  MTU is 1500 bytes
  Inbound  access list is 100
WIT
can you try this one:
ip flow ingress
duplex auto
speed auto
Config this access list:
ip access-list extended 100
permit tcp any any
permit udp any any
permit tcp any any eq 22
permit icmp any any echo
permit icmp any any traceroute
If this help then please rate.
Hi Sandeep
I just tried your configure, it's still not work. The result was same as last configure.
Could you post your sanitized running config and tell us from where you are trying this ping.
Regards.
Alain
Hi Alain,
Below is my router configuration
Current configuration : 3444 bytes
! Last configuration change at 09:20:03 UTC Mon Jun 4 2012 by aaabbb
! NVRAM config last updated at 11:16:51 UTC Mon May 21 2012 by aaabbb
version 15.2
hostname xxx
boot-start-marker
boot-end-marker
enable secret 5 $1$Oo.I$WOvVZ1MJWkDqAXupZioCQ/
aaa new-model
aaa authentication enable default group radius
aaa session-id common
no ipv6 cef
ip cef
license udi pid CISCO1941/K9 sn FGL160226BE
username aaabbb privilege 15 secret 5 $1$JRTo$mAU1yOzNFMH7jONZAMs/r0
interface Tunnel0
ip address 10.188.188.1 255.255.255.252
keepalive 10 3
tunnel source 10.100.118.238
tunnel destination 10.100.118.226
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip flow ingress
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.200.1 255.255.255.0
ip flow ingress
duplex auto
speed auto
interface Serial0/0/0
no ip address
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1/0
no ip address
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface Vlan1
ip address 10.100.118.238 255.255.255.252
router ospf 100
network 10.100.118.236 0.0.0.3 area 0
network 172.29.1.0 0.0.0.255 area 0
router bgp 65000
bgp log-neighbor-changes
network 10.188.188.1 mask 255.255.255.255
neighbor 10.100.118.226 remote-as 65001
neighbor 10.100.118.226 shutdown
neighbor 10.100.118.226 ebgp-multihop 4
neighbor 10.100.118.226 update-source Vlan1
neighbor 10.100.118.226 prefix-list BGP_UIH out
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.200.2
ip route 10.3.56.0 255.255.255.0 172.29.1.1
ip route 172.15.1.0 255.255.255.0 172.29.1.1
ip route 172.17.1.0 255.255.255.0 172.29.1.1
ip route 172.20.1.0 255.255.255.0 172.29.1.254
ip route 172.20.10.0 255.255.255.0 172.29.1.254
ip route 172.21.10.0 255.255.255.0 172.29.1.254
ip route 172.21.20.0 255.255.255.0 172.29.1.254
ip route 172.27.1.16 255.255.255.252 172.29.1.1
ip route 172.31.200.0 255.255.255.0 172.29.1.254
ip route 172.32.100.0 255.255.255.0 172.29.1.1
ip access-list extended test
permit ip any any
ip prefix-list BGP_UIH seq 5 permit 10.188.188.1/32
ip sla responder
access-list 90 permit 10.188.188.1
access-list 99 permit 172.20.1.0 0.0.0.255
access-list 199 permit ip 172.20.1.0 0.0.0.255 192.168.103.0 0.0.0.255
arp 172.29.1.254 0c85.25fa.2145 ARPA
route-map AAAA permit 10
match ip address 99
route-map AAAA deny 15
route-map test permit 10
match ip address 199
set interface Tunnel0
route-map test permit 20
control-plane
line con 0
privilege level 15
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
transport input all
scheduler allocate 20000 1000
end
I ping from the xxx router that I applied access-list.
WIT
can you do this:
debug interface g0/0
debug ip pack detail 198
debug arp
conf t
access-list 198 permit icmp any any
logging buffered debug
logging buffered 100000
logging console 6
do clear access-list counters
do clear arp
do ping 172.129.1.2 rep 1
do sh arp
do sh log
do sh access-list 100
and post outputs from the 3 show commands.
Regards.
Alain
Hi Alain,
xxx(config)#do sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.100.118.237          0   0010.dbec.4226  ARPA   Vlan1
Internet  10.100.118.238          -   2894.0f2a.fd63  ARPA   Vlan1
Internet  172.29.1.1              0   c89c.1dd1.4681  ARPA   GigabitEthernet0/0
Internet  172.29.1.2              -   2894.0f2a.fd60  ARPA   GigabitEthernet0/0
Internet  172.29.1.254            -   0c85.25fa.2145  ARPA
Internet  192.168.200.1           -   2894.0f2a.fd61  ARPA   GigabitEthernet0/1
Internet  192.168.200.2           0   0050.7fcc.8ce4  ARPA   GigabitEthernet0/1
xxx(config)#do sh log
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level informational, 180 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 40 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 183 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (100000 bytes):
Jun  4 10:32:19.430: ARP: flushing ARP entries for all interfaces
Jun  4 10:32:19.430: IP ARP: sent rep src 172.29.1.2 2894.0f2a.fd60,
                 dst 172.29.1.2 ffff.ffff.ffff GigabitEthernet0/0
Jun  4 10:32:19.430: IP ARP: sent rep src 192.168.200.1 2894.0f2a.fd61,
                 dst 192.168.200.1 ffff.ffff.ffff GigabitEthernet0/1
Jun  4 10:32:19.430: IP ARP: sent rep src 10.100.118.238 2894.0f2a.fd63,
                 dst 10.100.118.238 ffff.ffff.ffff Vlan1
Jun  4 10:32:19.430: IP ARP: sent req src 10.100.118.238 2894.0f2a.fd63,
                 dst 10.100.118.237 0010.dbec.4226 Vlan1
Jun  4 10:32:19.430: IP ARP: sent req src 192.168.200.1 2894.0f2a.fd61,
                 dst 192.168.200.2 0050.7fcc.8ce4 GigabitEthernet0/1
Jun  4 10:32:19.430: IP ARP: sent req src 172.29.1.2 2894.0f2a.fd60,
                 dst 172.29.1.1 c89c.1dd1.4681 GigabitEthernet0/0
Jun  4 10:32:19.430: IP ARP: rcvd rep src 192.168.200.2 0050.7fcc.8ce4, dst 192.168.200.1 GigabitEthernet0/1
Jun  4 10:32:19.430: IP ARP: rcvd rep src 172.29.1.1 c89c.1dd1.4681, dst 172.29.1.2 GigabitEthernet0/0
Jun  4 10:32:19.430: IP ARP: rcvd rep src 10.100.118.237 0010.dbec.4226, dst 10.100.118.238 Vlan1
Jun  4 10:32:19.758:  IP: s=172.21.20.15, d=192.168.103.22, pak 29DC6254 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jun  4 10:32:20.682:  IP: s=172.21.20.15, d=192.168.103.22, pak 30483D10 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
xxx(config)#do sh access-list 100
Additionnal info.
I think I have to apply "ip access-group 198 in" on int gi0/0 and show access-list 198.
xxx#sho access-lists 198
Extended IP access list 198
    10 permit icmp any any
I found log below.
Jun  4 10:35:05.374:  IP: s=172.29.1.2, d=172.29.1.2, pak 29DB86D4 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jun  4 10:35:07.374:  IP: s=172.29.1.2, d=172.29.1.2, pak 3141F3E4 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jun  4 10:35:07.374:  IP: s=172.29.1.2, d=172.29.1.2, pak 299A23C4 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jun  4 10:35:09.374:  IP: s=172.29.1.2, d=172.29.1.2, pak 28EE99C8 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Jun  4 10:35:11.374:  IP: s=172.29.1.2, d=172.29.1.2, pak 30483D10 consumed in input feature , packet consumed, Access List(31), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
I'm not sure, is it the problem that extended access-list is not work ?
Hi Sandeep,
     I tried to apply your configure again, it's still not work.
WIT
hi please correct your config  :
permit ip any any
ip access-group 100 in------------>>>>>>>put this>>>>>--(ip access-list extended test in)
ip flow ingress
duplex auto
speed auto
your extended access-list anme and where you are applying(To the interface) this list, the name should be same.
correct your config and try: it will work 100%.
I am attaching the whole new config for u:
please check...what is the changes:
Sandeep
Dear Sandeep,
I tried to apply below configure (As your suggest). It's sitll not work
ip access-group test in
ip flow ingress
duplex auto
speed auto
permit ip any any
xxx#ping 172.29.1.1
Sending 5, 100-byte ICMP Echos to 172.29.1.1, timeout is 2 seconds:
WIT
write here
sh ip route
sh interface GigabitEthernet0/0
xxx#ping 172.29.1.2
xxx#ping 172.29.1.1
xxx#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.200.2 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.200.2
      10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
S        10.3.56.0/24 [1/0] via 172.29.1.1
O E2     10.100.118.224/30 [110/0] via 10.100.118.237, 2d23h, Vlan1
O E2     10.100.118.228/30 [110/0] via 10.100.118.237, 7w0d, Vlan1
C        10.100.118.236/30 is directly connected, Vlan1
L        10.100.118.238/32 is directly connected, Vlan1
O E2     10.100.118.240/30 [110/0] via 10.100.118.237, 1w1d, Vlan1
C        10.188.188.0/30 is directly connected, Tunnel0
L        10.188.188.1/32 is directly connected, Tunnel0
      172.15.0.0/24 is subnetted, 1 subnets
S        172.15.1.0 [1/0] via 172.29.1.1
      172.17.0.0/24 is subnetted, 1 subnets
S        172.17.1.0 [1/0] via 172.29.1.1
      172.20.0.0/24 is subnetted, 2 subnets
S        172.20.1.0 [1/0] via 172.29.1.254
S        172.20.10.0 [1/0] via 172.29.1.254
      172.21.0.0/24 is subnetted, 2 subnets
S        172.21.10.0 [1/0] via 172.29.1.254
S        172.21.20.0 [1/0] via 172.29.1.254
      172.27.0.0/30 is subnetted, 1 subnets
S        172.27.1.16 [1/0] via 172.29.1.1
      172.29.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.29.1.0/24 is directly connected, GigabitEthernet0/0
L        172.29.1.2/32 is directly connected, GigabitEthernet0/0
      172.31.0.0/24 is subnetted, 1 subnets
S        172.31.200.0 [1/0] via 172.29.1.254
      172.32.0.0/24 is subnetted, 1 subnets
S        172.32.100.0 [1/0] via 172.29.1.1
      192.168.200.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.200.0/24 is directly connected, GigabitEthernet0/1
L        192.168.200.1/32 is directly connected, GigabitEthernet0/1
xxx#sh interface GigabitEthernet0/0
  Hardware is CN Gigabit Ethernet, address is 2894.0f2a.fd60 (bia 2894.0f2a.fd60)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:05, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 21000 bits/sec, 9 packets/sec
  5 minute output rate 26000 bits/sec, 8 packets/sec
     96062788 packets input, 2446708931 bytes, 0 no buffer
     Received 267781 broadcasts (0 IP multicasts)
     0 watchdog, 267711 multicast, 0 pause input
     89102613 packets output, 2350737648 bytes, 0 underruns
     178466 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
xxx#ping 172.29.1.2
Success rate is 0 percent (0/5)
xxx#ping 172.29.1.1
WIT
