POS Loopback Testing
vblaha
I am trying to put up a loopback to my self by issueing the looback internal command but when I do so the interface shows up/down looped.  Shouldnt it show up up looped?  Do I need to do somehting else?
pcf-ipfr#sh int pos2/0
POS2/0 is up, line protocol is down (looped)
  Hardware is Packet over Sonet
  Internet address is 172.x.x.x.x.xx.x.x
  MTU 4470 bytes, BW 155000 Kbit, DLY 100 usec,
  Encapsulation PPP, LCP REQsent, crc 32, loopback set (internal)
  Keepalive set (10 sec)
  Scramble enabled
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 00:12:57
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/205/256 (active/max active/max total)
     Reserved Conversations 1/1 (allocated/max allocated)
     Available Bandwidth 139500 kilobits/sec
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     217 packets input, 29697 bytes, 0 no buffer
     Received 0 broadcasts, 1 runts, 0 giants, 0 throttles
              0 parity
     42 input errors, 68 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort
     195 packets output, 3986 bytes, 0 underruns
     0 output errors, 0 applique, 4 interface resets
     1 carrier transitions
paolo bevilacqua
That is normal with PPP.
If you were to use HDLC encap, it would would show up/up (looped).
Ok then I would be able to run the ping test correct?  Would I be pinging my local interface?
Yes, but that is irrelevant for diagnostic purposes.
Please remember to rate useful posts clicking on the stars below.
