Extended ACLs and Policy Based Routing
ncariaga52682
I would like to ask if it is possible to use a extended ACL in defining a route-map? the extended ACL includes a specific source ip and a destination IP. I tried doing this however when I tested using traceroute, I noticed a specific hop where a packet timed out. Please refer to the attached screenshots. Thank you.
Giuseppe Larosa
Hello Nathanael,
it is possible to use extended ACLs with PBR.
match ip address
see command reference for 12.4 mainline
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_pi1.html#wp1013725
it clearly states the invoked ACL can be extended.
what you see may be related to the presence of the command
no ip unreachables
on the next-hop device on the interface towards traceroute source.
Hope to help
Giuseppe
Hi Giuseppe,
Thank you for your response. To be honest, I already tried this prior starting this thread. However, I noticed that the 3rd hop timed out when I was trying to test the configuration. I thought i did something wrong with my configuration which caused the 3rd hop to timed out (please see the attached image at the start of this thread).
Thanks again for your response.
