Extended VLAN range
mahadhema
I've downlowded the new IOS relase 12.1(22)EA5 for Cisco2950 switch in order to support the full range of VLAN IDs as mentioned on Cisco site
http://www.cisco.com/en/US/products/sw/iosswrel/ps5013/prod_bulletin0900aecd802efa1c.html
After upgrading the switch and tried to create vlan 2000 i got the following error message (% Failed to create VLANs 2000 VLAN(s) not available in Port Manager.
%Failed to commit extended VLAN(s) changes)
Please adivce what could be the cause of that?
Edison Ortiz
What's the current VTP status on that switch ?
Extended VLANs are only supported when the switch is set to VTP Transparent. It won't work when the switch is set to VTP Server or Client.
Please rate helpful posts.
I changed the VTP mode to transparnet and it worsk fine...
Thanks for your help...
