08-02-2006 03:29 PM - edited 03-03-2019 01:31 PM
I have a GRE/IPSec tunnel between to facilities and they are runnning EIGRP info across the tunnel.
I want to extend the same VLAN across this tunnel so that both sites can have the same VLAN's and VTP domain info.
Is there a way to do this?
I have attached a config of one side of the GRE tunnel.
08-02-2006 10:21 PM
This is do-able but not through GRE/IPSec Tunnel, it's called L2 VPN or L2TPv3.
L2TPv3 Operation
L2TPv3 provides similar and enhanced services to replace the current UTI implementation, including the following features:
?Xconnect for Layer 2 tunneling via a pseudowire over an IP network
?Layer 2 VPNs for PE-to-PE router service via Xconnect that support Ethernet, 802.1q (VLAN), Frame Relay, HDLC and PPP Layer 2 circuits, including both static (UTI-like) and dynamic (using the new L2TPv3 signaling) forwarded sessions
FAQ if you have question why can't GRE/IPSec work?
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_q_and_a_item09186a00800a443e.shtml
Please rate helpful posts.
08-02-2006 10:27 PM
You can do 2 things
1) Run MPLS on top of tunnels and as suggested earlier, AtOM (EoMPLS) and L2TPv3 should help u extend the VLANs.
2) Run IRB over the GRE tunnels and bridge all the traffic from the VLANs into the GRE.
