External EIGRP routes manipulation
Here is my topology left to right
router A <eigrp redistribute static>---> ASA eigrp advertise out Gig0/1 and Gig0/2 ---------> router B receiving external eigrp routes via both ASA interfaces
I need router B to have only one route in it's routing table for the external routes ASA is advertising out interface Gig0/1
I have tried off-set list, delay on interface, distribute list in for Gig0/2 with route-map applied with a higer metric. All these methods seem to only change foe internal eigrp routes and does not affect the metric for external.
Any ideas
Jon Marshall
Apologies, that was a very stupid question.
I'll get back to you :)
Jon
Jon Marshall
So I am assuming router B has two interfaces as well because the ASA interfaces will be in separate subnets, is that correct ?
If so I just did a quick lab and increased the delay to the interface on router B you do not want to use and it worked fine for me.
Jon
