External HTTP Traffic to internal WebServer
I have just installed a router and setup NAT port forwarding for passing internet traffic to internal systems running things such as HTTPS, RDP, redirecting ports, etc. Everything is working great except port 80. HTTP traffic is not working and i need a little help please with the config.
interface FastEthernet0/0 (OUTSIDE)
IP 40.40.40.2
IP NAT OUTSIDE
interface FastEthernet0/1 (INSIDE)
IP 192.168.60.2
IP NAT INSIDE
no ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.60.80 80 interface fastEthernet0/0 80
ip nat inside source static tcp 192.168.60.21 443 interface FastEthernet0/0 443
ip nat inside source static tcp 192.168.60.21 3389 interface FastEthernet0/0 3389
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 100 permit tcp any host 192.168.60.80 eq www
Any help would be appreciated
If all your other static translations are working then it doesn't seem to be a problem with the router because there is nothing obviously wrong with that specific NAT entry.
It could be an issue with the server itself ie.
1) does it have the correct default gateway set ?
2) does it actually work internally ?
Jon
6 Replies 6
Jon Marshall
Difficult to say with the limited configuration you have posted.
The only thing that stands out is your acl 100 is referencing the private IP of the web server and it should be referencing the public IP you are translating the web server to.
But that is just a guess based on what you have posted because you don't show if that acl is applied anywhere or what else is in it.
Jon
Jon, Thanks for the reply and sorry for the delay.
Below is the config please look over and give your thoughts. If i can provide anything else, please let me know.
Current configuration : 8432 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname Router
boot-start-marker
boot system flash c2800nm-advipservicesk9-mz.124-7a.bin
boot-end-marker
no logging on
enable secret 5 $1$FXfM$44YnheWldPjnzzChbNnof0
enable password 7 075D0E404A5B1A1045
no aaa new-model
resource policy
clock timezone CST -6
clock summer-time CST date Mar 9 2008 2:00 Nov 2 2008 2:00
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.60.1 192.168.60.99
ip dhcp excluded-address 192.168.60.225 192.168.60.254
ip dhcp pool DHCP
   import all
   network 192.168.60.0 255.255.255.0
   domain-name domain
   dns-server 192.168.60.21 192.168.60.23
   netbios-name-server 192.168.60.21 192.168.60.23
   default-router 192.168.60.2
   lease 7
no ip bootp server
ip domain name domain.com
ip name-server 8.8.8.8
voice-card 0
 dspfarm
password encryption aes
voice call carrier capacity active
voice service pots
voice class codec 1
 codec preference 1 g711ulaw
voice class h323 1
 h225 timeout tcp establish 2
interface Loopback1
 ip address 192.168.117.1 255.255.255.0
 ip virtual-reassembly
 ip address 40.40.40.2 255.255.255.248
 ip nat outside
 no ip virtual-reassembly
 no ip mroute-cache
 duplex full
 speed auto
 no cdp enable
 no mop enabled
 ip address 192.168.60.2 255.255.255.0
 ip nat inside
 duplex full
 speed auto
 no cdp enable
interface Serial0/2/0
 no ip address
 shutdown
ip route 0.0.0.0 0.0.0.0 40.129.178.169
ip route 192.168.0.0 255.255.0.0 192.168.60.1
no ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.60.80 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.60.21 3389 interface FastEthernet0/0 61046
ip nat inside source static tcp 192.168.60.29 25 interface FastEthernet0/0 25
ip nat inside source static tcp 192.168.60.23 81 interface FastEthernet0/0 81
ip nat inside source static tcp 192.168.60.6 8990 interface FastEthernet0/0 8990
ip nat inside source static tcp 192.168.60.6 8991 interface FastEthernet0/0 8991
ip nat inside source static tcp 192.168.60.6 3050 interface FastEthernet0/0 3050
ip nat inside source static tcp 192.168.60.6 1024 interface FastEthernet0/0 1024
ip nat inside source static tcp 192.168.60.18 82 interface FastEthernet0/0 82
ip nat inside source static tcp 192.168.60.18 1911 interface FastEthernet0/0 1911
ip nat inside source static tcp 192.168.60.29 3011 interface FastEthernet0/0 3011
ip nat inside source static tcp 192.168.60.16 8100 interface FastEthernet0/0 8100
ip nat inside source static tcp 192.168.60.84 444 interface FastEthernet0/0 444
ip nat inside source static tcp 192.168.60.253 3389 interface FastEthernet0/0 61047
ip nat inside source static tcp 192.168.60.23 3389 interface FastEthernet0/0 61035
ip nat inside source static tcp 192.168.60.10 3389 interface FastEthernet0/0 62035
ip nat inside source static tcp 192.168.60.9 3389 interface FastEthernet0/0 61032
ip nat inside source static tcp 192.168.60.250 3389 interface FastEthernet0/0 61039
ip nat inside source static tcp 192.168.60.244 3389 interface FastEthernet0/0 61041
ip nat inside source static tcp 192.168.60.8 3389 interface FastEthernet0/0 61043
ip nat inside source static tcp 192.168.60.6 3389 interface FastEthernet0/0 61044
ip nat inside source static tcp 192.168.60.21 53 interface FastEthernet0/0 53
access-list 100 permit tcp any host 40.40.40.2 eq www
snmp-server community public RO
control-plane
voice-port 0/0/0
 output attenuation 6
 echo-cancel coverage 32
 no non-linear
 playout-delay maximum 120
 playout-delay nominal 100
 playout-delay mode fixed
 no comfort-noise
 timeouts call-disconnect 3
 connection plar 1234567890
 description THE CONNECTION PLAR WAS ESSENTIAL TO AVOID TWO STAGE DIALING
 bearer-cap Speech
 caller-id enable
voice-port 0/0/1
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
voice-port 0/0/2
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
voice-port 0/0/3
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
voice-port 0/1/0
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
voice-port 0/1/1
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
voice-port 0/1/2
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
voice-port 0/1/3
 no non-linear
 no comfort-noise
 bearer-cap Speech
 caller-id enable
dial-peer voice 10 pots
 destination-pattern 9.
 direct-inward-dial
 port 0/0/0
dial-peer voice 11 pots
 direct-inward-dial
 port 0/0/1
dial-peer voice 12 pots
 direct-inward-dial
 port 0/0/2
dial-peer voice 13 pots
 direct-inward-dial
 port 0/0/3
dial-peer voice 14 pots
 direct-inward-dial
 port 0/1/0
dial-peer voice 15 pots
 direct-inward-dial
 port 0/1/1
dial-peer voice 16 pots
 direct-inward-dial
 port 0/1/2
dial-peer voice 17 pots
 direct-inward-dial
 port 0/1/3
dial-peer voice 100 voip
 destination-pattern .
 session protocol sipv2
 session target ipv4:192.168.1.24
 dtmf-relay rtp-nte
 codec g711ulaw bytes 240
 ip qos dscp cs5 media
 no vad
dial-peer voice 99999 voip
 incoming called-number 9.
 dtmf-relay rtp-nte
 no vad
gateway
 timer receive-rtp 1200
sip-ua
 set pstn-cause 8 sip-status 404
 set pstn-cause 16 sip-status 486
 set pstn-cause 101 sip-status 501
 retry invite 2
 retry response 2
 retry bye 2
 retry cancel 2
 timers trying 1000
 timers connect 1000
banner motd ^C
*******        Unauthorized Entry is Prohibited        *******
**************************************************************^C
line con 0
 exec-timeout 0 0
line aux 0
line vty 0 5
 exec-timeout 30 0
 password 7 02542B570F540C341E
 login
scheduler allocate 20000 1000
no process cpu extended
no process cpu autoprofile hog
end
thanks for your help
Jon
Good heavens Jon, the default gateway was the issue. Apparently we missed changing the default gateway on that server. I did work internally so i made an assumption that it had been updated when we changed the network structure. Sometimes you need another set of eyes. Thanks for your help and have a great day.
No problem, glad you got it working.
Jon
Hello
Can you please rate Jons assistance and the post as answered
As it may help others in the future.
res
Paul
Kind Regards
Paul
