Fabric Path & HSRP
clark white
Level 2
Level 2
Dears
Please find the attached topology.
I have 2 Nos 7K and 2 Nos 5K, and i am enabling the fabric path between them, i am confused for the fabric path switch ID, 2 No's 7K switch ID will be different than the emulated switch ID. Because i have read the document that if you want HSRP to works in Active/Active data plane then the emulated switch-ID used in vPC domain should be same.
Please confirm the configs are correct to work this topology
N7K-A
fabricpath domain default
fabricpatch switch id 1000
vpc domain 1
role priority 1
fabricpath switch-id 2000    ----should be same on both 7K if we want HSRP data plane as active/active
int po2
sw mode fabricpath
vpc peer-link
int ether 1/7-8
sw mod fabricpath
N7k-B
fabricpatch switch id 1001
vpc domain 1
role priority 10
int po2
sw mode fabricpath
vpc peer-link
int ether 1/7-8
sw modw fabricpath
clark white
Level 2
Level 2
Dear Experts,
Anybody canhelp for the above query.
Clark,
You are correct - config looks clean.  Look at the config below.  Also take a look at the Quick Start Guide ::  FabricPath for more config details and best practice recommendations.  https://supportforums.cisco.com/community/netpro/data-center/others?view=documents
