Factory Default Reset
naveen_yummy
Level 2
Level 2
Hello all,
My team already bought one 1800 Series router. And they setted some passwor.
Right now i am not able to login. I know the cisco password recovery method to reset the password.
Instead of password recovery method i want to try with total factory default setting.
is there is any method to do factory default without login
Thanks in Advance
BR
Naveen
5 Replies 5
paolo bevilacqua
With password recovery, the router boots with factory default configuration.
At the prompt type wr mem and the default is then saved.
Then configure the startup register again.
Alessio Andreoli
Level 11
Level 11
Hi there,
a) enter in rommon configuration
b) rename config.text config.old
c) reboot the router
d) once the router loaded the IOS just erase the config.old file
Hope this helps
Alessio
naveen_yummy
Level 2
Level 2
Hi guys,
thanks for the replies.
I jst asking about withut going to rommon is there is any possibilites are there?
Dont know it will not but just wanna to get some ideas from all
BR
naveen
Do a 'write erase' command and 'reload.'
Rick Morris
Level 11
Level 11
No, you need to get into device and erase the config.
Since you know the password recovery, perform this step and then once in erase the config.
