failover and load balance
ntmanjunath
The two ISP connected single router Serial0 (BSNL)1M and another Fethernet0 (SPECTRANET)2M as per the attached fig.Please provide the failover and load balance configuration as per the below said configuration.
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ETH-LAN$
ip address 203.x.x.129 255.255.255.240 secondary
ip address 203.x.x.113 255.255.255.240
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip route-cache flow
ip policy route-map secptranet
duplex auto
speed auto
interface FastEthernet0/1
description " 2 MB LINK To SPECTRANET"
ip address 203.x.x.134 255.255.255.252
shutdown
duplex auto
speed auto
interface Serial0/0/0
description TO VSNL 1 MB LINK
ip address 59.x.x.25 255.255.255.252
ip classless
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 100
ip access-list standard Xor@
ip access-list standard verion
access-list 150 permit ip 203.92.59.128 0.0.0.15 any
snmp-server community Xor@ RW
snmp-server location Bangalore
snmp-server contact network admin ikazi@xora.com
snmp-server chassis-id 1841
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps entity
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps vtp
snmp-server host 192.168.102.206 version 2c Xor@
no cdp advertise-v2
route-map secptranet permit 5
match ip address 150
set ip next-hop 203.92.62.133
tarunavakonar
u have any FW?
if u have u have to put PBR
and Nating on router is required
plz provide the diagram
The firwall using sonicwall.The diagram is attached already.
