failover between s2s vpn link and MPLS link in single router
adamov123
hi all
i have a client who have single cisco router 1800 series router at a branch site , both MPLS and S2S vpn is available to head office he want link load balancing and  failover between the two connection and if VPN fails he want the router to wait 15 minutes before routing all the traffic through the MPLS line
the problem is if we configure ip SLA we canot track the route of VPN because there is no static route associated with it ,please I need a help how can I make his demands possible
Simon Brooks
Ip sla and ping next hop in vpn if it fails then route over mpls.
Sent from Cisco Technical Support Android App
thanks for the reply , but i have a problem with that , VPN and MPLS are configured at the same router , so my question is how can i track  the VPN route(track configuration in IP SLA), so that if SLA detects that vpn is down all trafiic will take the mpls route
Can you upload configuration and some sketch to make your question more clear?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
