04-09-2012 02:36 AM - edited 03-04-2019 03:57 PM
Hello
I got setup where Site A is connected to Site B , Site B is connected to Site C
A------------B-----------------C
Site A connected to Site B < GRE over IPSEC with OSPF >
Site B connected to Site C < Point to Point >
To have redundancy betwen Site A and Site C we configured < GRE over IPSEC >
Traffic dont pass from Site A to Site C using the GRE Tunnel when we manullay shutdown the interface on Site C
( interface which is P-2-P with Site B )
show ip route output indicates traffic still passing A-----B------C
unless
i have a static route on Site A
ip route 172.16.50.0 255.255.255.0 Tunnel 2 ( Tunnel 2 is GRE tunnel between Site A and Site C )
We prefer to have Primay path for Site C from Site A -> A ------------ B ------------------C
if link between B------C is down then
Failover path would be A-------------------C
Appreciate some input
thanks
Vishal
04-09-2012 07:24 AM
On router A you can give a static route to use the link b/w B and C and track the connectivity to C through a SLA
the other route from A to C should have a higher AD, so once the SLA fails the direct route will be installed immediatly.
04-10-2012 07:57 AM
totally agree with the above post.
Site A router needs to know that link between SiteB & C is down, so either make modifications in SiteB so that OSPF stop sending the SiteC subnet(172.16.50.0/24) route over to SiteA so that failover to a secondary route can happen or use IP SLA feature with static route for failover
Hope it helps
Neeraj
