Failover on Cisco Router 1800 having DSL & Leased Line
Hi there!
Below is my description:
  • Leased line is between dammam      to dubai and the dammam office is getting internet from dubai.
  • The ip address of Dammam      office is class A (Public IP) x.x.x.x and for dubai it is y.y.y.y which we are      using as proxy for accessing internet.
  • I purchase the local DSL      direct line connection through cable from Local Provider and this ip address range is      192.168.1.0 - 192.168.1.254.
  • Is it possible to use the DSL      line as failover, so if one line goes down the user should remove proxy      and can use local internet.
  • The router which is using is      cisco 1800.
I believe that failover is possible, 100%, but would like to know how I can do it and requesting for sharing more inputs about failover in this case.
Documents will be much appreciated...
Thanks & Regards,
Yaseen
chad patterson
This is possible and relatively simple to acheive: depending on whether you are NATing or not. Either way it can be acheived with IP SLA and Tracking.
You might look at this discussion.
If were you I might just use both as the primary, and load share between the two using PfR/OER. I have done that and it works well. Refer to the second document that.
chad patterson
By the way, I highly recommend including this line in your config:
ip nat translation tcp-timeout 3600
as it will prevent some of the memory fragmentation issues that may arise due to the NATing.
