Failover Route
J2NoomSai_2
Hi Masters
Please advise my problem. I have branch office that will have PTP with 2xT1 and VPN through DIA. We want PTP to be the main path to our HQ and VPN as a backup. I attached diagram and please advise how to setup failover if PTP fail that the traffic will go through VPN. I believe we have to setup on 3750 L3 switch. NOt sure. BTW, we use EIGRP.
Sai
Marwan ALshawi
u have two options
first increase the delay number on the interface of the router u wanted to act as back up
or creat a dont include the network between the main offie router or L3 switch and tha back up router
and creat a static route to the remote network trhough the back up router with higer metwric it should be more than 90
good luck
if helpful Rate
Thanks Mar. We use public IP on VPN edge router and also outisde Interface of PIX. We been using relay and HSRP for failover. But with PIX, is anything to do with it? Since VPN router both outside and Inside interface are using public IP.
Sai
