09-05-2008 07:16 AM - edited 03-03-2019 11:25 PM
I configured a IPSec between a hub-router and some spoke-routers. All things work fine.
My next step is to filter traffic between the sites by ACL's.
One of the ACL's is:
ip access-list extended gre_hub-spoke1
permit gre host 172.31.254.254 host 172.31.254.1
permit ip 10.70.0.0 0.0.0.255 192.168.10.0 0.0.0.255
This ACL matches to the crypto map:
crypto map gre-tunnel 10 ipsec-isakmp
set peer 172.31.254.1
set transform-set myset
match address gre_hub-spoke1
Why is the behavior different than configured?
The "permitted" communication is blocked, other traffic is forwarded.
Thanks and kind regards
Matthias
Solved! Go to Solution.
09-05-2008 07:52 AM
From the Crypto acl:
permit gre host 172.31.254.254 host 172.31.254.1 ---------------> SAs are built and the traffic is going through
permit ip 10.70.0.0 0.0.0.255 192.168.10.0 0.0.0.255 ---------------------> there are no SA built for it! Check for mirror image acl entry for it on other side in crypto acl.
Saju
Please rate if it helps.
09-05-2008 07:29 AM
Do you see IPSEC sa being built for that traffic? Post output of "show crypto ipsec sa". Do you see encrypts/decrypts ?
Saju
09-05-2008 07:37 AM
09-05-2008 07:52 AM
Saju
