Failover with two ADSL links
salman abid
Hi Guys,
At one of my remote location currently it is connected to headoffice by using a 40Mbps ADSL link for VPN and NAT but in running week i'll get a 10Mbps ADSL additional link.
I have 2911 router and on that router 1 port gig0/2 is free so i'll connect that 10Mbps link on that port. Actually i want to configure failover with active/standby between 40Mbps and 10Mbps link for VPN and NAT both.
As right now i have configured dialer0 for 40Mbps link then after connectivity 10Mbps on gig0/2 do i need to create an other dialer interface??? if yes then what will be the configuration.
Kindly adivse me on same.
Below is the current config of 2911 router.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.02.09 11:20:28 =~=~=~=~=~=~=~=~=~=~=~=
Current configuration : 8113 bytes
! Last configuration change at 19:06:39 AST Fri Jan 17 2014
! NVRAM config last updated at 19:06:55 AST Fri Jan 17 2014 by admin
version 15.1
no service pad
hostname OCSRTR
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 16384
enable secret 4 Ckg/sS5mzi4xFYrh1ggXo92THcL6Z0c6ng70wM9oOxg
no aaa new-model
clock timezone AST 4 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.142.1 192.168.142.10
ip dhcp excluded-address 192.168.150.1 192.168.150.30
ip dhcp pool VOICE
network 192.168.142.0 255.255.255.0
default-router 192.168.142.1
option 150 ip 10.1.2.11 10.1.2.12
ip dhcp pool mypool
import all
network 192.168.150.0 255.255.255.0
default-router 192.168.150.1
dns-server 192.6.14.189 192.6.14.182
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol pass-through g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^45./ /400/
rule 2 /^46./ /400/
rule 3 /^47./ /400/
voice translation-rule 2
rule 1 /^0\(2.......\)$/ /00\1/
rule 2 /^0\(3.......\)$/ /00\1/
rule 3 /^0\(4.......\)$/ /00\1/
rule 4 /^0\(5........\)$/ /00\1/
rule 5 /^0\(6.......\)$/ /00\1/
rule 6 /^0\(7.......\)$/ /00\1/
rule 7 /^0\(9.......\)$/ /00\1/
rule 8 /^00\(.*\)/ /0\1/
rule 9 /^.......$/ /0&/
rule 10 // /000\1/
voice translation-rule 3
rule 1 /^45./ /6072400/
rule 2 /^46./ /6072400/
rule 3 /^47./ /6072400/
rule 4 /^4../ /6072&/
voice translation-profile FROM_PSTN
translate calling 2
translate called 1
voice translation-profile TO_PSTN
translate calling 3
license udi pid CISCO2911/K9 sn FGL16441279
hw-module pvdm 0/0
hw-module sm 1
username admin privilege 15 secret 4 Ckg/sS5mzi4xFYrh1ggXo92THcL6Z0c6ng70wM9oOxg
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-10,16
crypto ipsec client ezvpn OCS_Deira
connect auto
group OCS_Deira key xxxxxxx
mode network-extension
peer 83.xx.xx.xx
nat allow
nat acl 110
xauth userid mode interactive
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.150.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
duplex auto
speed auto
crypto ipsec client ezvpn OCS_Deira inside
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.142.1 255.255.255.0
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.142.1
interface GigabitEthernet0/1
description *** CONNECTED TO 40Mbps link ***
no ip address
ip nat outside
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/2
shutdown
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface SM1/0
ip unnumbered GigabitEthernet0/0.2
service-module ip address 192.168.142.2 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 192.168.142.1
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxxx password 0 xxxxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.142.2 255.255.255.255 SM1/0
access-list 110 deny   ip 192.168.150.0 0.0.0.255 192.6.14.0 0.0.0.255
access-list 110 deny   ip 192.168.150.0 0.0.0.255 10.1.0.0 0.0.255.255
access-list 110 deny   ip 192.168.142.0 0.0.0.255 192.6.14.0 0.0.0.255
access-list 110 deny   ip 192.168.142.0 0.0.0.255 10.1.0.0 0.0.255.255
access-list 110 permit ip 192.168.150.0 0.0.0.255 any
access-list 110 permit ip 192.168.142.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 110
snmp-server community jash RO
snmp-server location -------Dubai OCS----
snmp-server contact Mr.Sivakumar
snmp-server enable traps tty
snmp-server enable traps cpu threshold
snmp-server enable traps syslog
snmp-server host xxx.xxx.xx version 2c jash
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
password Admin456
login
transport input all
line vty 5 15
password Admin456
login
transport input all
scheduler allocate 20000 1000
ntp master 1
end
OCSRTR#exi
Vishesh Verma
Yes, you need to create a second dialer interface, which will provide connectivity through second physical interface. Let's say second interface is Dialer1.
Now you need to setup failover if Dialer0 is down. For doing that you would need an ip sla and a track
!***IP SLA config to track reachability of internet via Dialer0***
ip sla 1
icmp-echo 4.2.2.2 source dialer0
frequency 5
ip sla schedule 1 start now life forever
track 1 ip sla 1 reachability
!***Route Failover if internet is down via Dialer0***
ip route 4.2.2.2 255.255.255.255 Dialer0 permanent
ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer1 100
!***NAT config***
interface Dialer0
ip nat outside
interface Dialer1
ip nat outside
ip nat inside source route-map nonat0 interface Dialer0 overload
ip nat inside source route-map nonat1 interface Dialer1 overload
!***Route-map need to check the egress interface as well to make the decision to NAT the traffic***
route-map nonat0 permit 10
match interface Dialer0
route-map nonat1 permit 10
match interface Dialer1
end
Some low-end Cisco platforms may have trouble clearing the NAT  translations during failover so you can use an EEM script to clear NAT  translations if primary interface is down and traffic is switched to  secondary link. Refer to following post in which I wrote an EEM script  to take care of that.
https://supportforums.cisco.com/message/4156766
Now you make the configuration of EZVPN through backup link, of which I am no expert.
-Vishesh
@Vishesh
Thanks for the rply
so in case of dialer1 interface below can be the configuration????
description *** CONNECTED TO 10Mbps link ***
no ip address
ip nat outside
duplex auto
speed auto
pppoe-client dial-pool-number 1      <======   (do we need to keep it dial-pool-number 1  )
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1           <=====         (do we need to keep pool 1)
dialer-group 1          <=====         (do we need to keep group 1)
What about premption, i mean when the primary link will become up what will happen in that case.
For EZVPN we just need to put crypto command on Dialer1 interface same as i have given on Dialer0 interface.
Salman ,
Here are the answers:-
no ip address
ip nat outside
duplex auto
speed auto
Answer: This command helps to determine which dialer to bound with.
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
Answer: DIaler pool helps to understand which Fa/GE port are associated with it. numeric 1 identify it and the same number should be on the Ge/FE port.
Answer:- "Dialer group 1" helps to trigger the dialer when intresting traffic start flowing.
usually we put the following commnad under global configuration to make the above command to work.
dialer-list 1 protocol ip permit.
THis means that dialer 1 will be triggered and negotiate PPP when any ip traffic starts flowing.
Salman,
dialer-pool and dial-pool-number associates/binds the dialer interface with the physical interface, so i think they have to be different, then what we already use for our primary link. And dialer-group simply checking the dialer-list for intersting traffic (ip traffic in your case) so it can be same.
interface Dialer0
dialer pool 1
dialer-group 1
pppoe-client dial-pool-number 2
interface Dialer1
dialer pool 2
dialer-group 1
When fault in primary path is recovered, the track would come up hence the primary route would be installed in the routing table and the traffic would fall-back to the primary.
-Vishesh
