FECN on Frame Relay
binusam161
I am seeing lot of FECN's (1000's) on my Frame Relay Circuit daily.
Is that a big problem.
What is the FIX to this
mheusinger
Level 10
Level 10
the meaning of FECN (Forward Explicit Congestion Notification) in FR is, that a FR device reports an overload situation. It will then mark the FR frame experiencing this congestion with FECN bit. So it might simply mean, that your SP has an overbooked network, or that you are sending more traffic than your CIR would allow.
In case you are sure that you are within your traffic limits I would advise you to talk to your SP about it. Realistically they will not really modify their backbone, but rather turn of FECN bit setting and propagation towards your router.
In case you burst too much, configuring FR traffic shaping on the routers could help.
Hope this helps! Please rate all posts.
Regards, Martin
