What are some good tools to monitor routers?
dennylester
I am wondering what are some good tools for monitoring the health of our routers and circuits. We've always run with the SOHO mentality (hook it up and run it to death), but now we've grown to a point where monitoring is critical.
What does it take to log items like bandwidth utilization, error counts, BRI status, etc, etc.
What brings me to ask this is our frame cloud is starting to take perodic performance hits. I suspect we may have more remotes than our host can handle, but the problem doesn't seem to affect all remotes at the same time, so I'm not sure.
I know I can log into each and every router and look at the various statistics, but those snapshots don't paint a very clear picture.
I hope this makes sense.
Denny
5 Replies 5
m.matteson
Level 2
Level 2
check out http://cacti.net/. awesome. good luck.
rate if this helps :)
The product looks very interesting and the price is right. The only turn off for me is it is a Linux product. I'm certainly not opposed to setting up a Linux box but was hoping for something that would run on Windows.
I read through their site and the reporting looks nice, but it looks like a lot of manual setup.
DO you know if there is a bunch of predefined scripts for Cisco routers?
oh ya i thought that it only ran on linux at first too. but you can install it on windows. if you do that then you have unlimited access to anything microsoft because of WMI. there are pre-built templates for cisco products that you can use.
mounir.mohamed
Level 7
Level 7
Denny,
You are talking in very wide area there is a lot of tools & command can be used to achieve your goal, 1st you may perform simple configurations that enable the monitoring on ur router for simple example
the below link contain most of the monitoring commands
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/fun_r/frprt3/frmonitr.htm
Ex:
Interface s0/0
Load-interval 30  to check the bandwidth on the interface every 30 seconds
ip route-cache flow  to capture the incoming/outgoing traffic on the interface
Also you may enable SNMP with RO community and use any monitoring application that can create a useful output with a graphs about CPU/bandwidth/delay/packet loss..Etc
Famous applications:
Cisco Works http://www.cisco.com/en/US/products/sw/cscowork/ps2425/
SolarWinds http://www.solarwinds.net
Cyber Gauge http://www.neon.com/CGwin.shtml
MRT http://people.ee.ethz.ch/~oetiker/webtools/mrtg/
Sure some of the above applications can downloaded through emule, kaza..etc
Please rate helful posts
Best Regards,
Mounir Mohamed
bhedlund
Level 4
Level 4
Denny,
Check this one out too:
http://www.statseeker.com/Statseeker_Network_Monitoring_Software.html
Please rate this post.
Brad
