FF00::/8 Null0 Rule
PrimeYeti
I understand that this rule is used to
discard multicast
traffic sent to the router, but wouldn't this stop some of the fundamental IPv6 processes (e.g. NDP) from working? Why does the router add this automatically? And have I misunderstood its purpose?
2 Accepted Solutions
Hello @PrimeYeti,
The
FF00::/8 Null0
route should not be added or used to block all IPv6 multicast traffic. As you correctly pointed out, it is indeed counterproductive and can disrupt fundamental IPv6 processes like NDP, which are crucial for proper IPv6 routing and communication.
The
FF00::/8
range encompasses all IPv6 multicast addresses, and blocking it with a Null0 route effectively prevents any multicast traffic from being forwarded in the network. This would lead to severe communication issues, as many essential IPv6 protocols, including NDP, rely on multicast to function correctly.
Creating an ACL to allow specific multicast traffic to FF02 addresses would not solve the problem, as
FF02::/16
represents the
link-local multicast
addresses, and there are numerous important multicast groups within this range that are essential for local communication, such as Router Solicitation and Router Advertisement messages.
In a standard IPv6 configuration, routers should not add a
FF00::/8 Null0 route by default
as it would indeed cause problems and hinder IPv6 functionality. If such a route exists, it's essential to review the configuration and remove it to allow normal IPv6 multicast communication and ensure proper functioning of IPv6 routing and processes.
Best regards
You were in fact right - the
FF00::/8
routing entry is added to the routing table automatically by
IOS/IOS XE
It is not something that you configure - this happens automatically.
The trick here is that this route is added to the
unicast
routing table. It does not interfere with real multicast routing if that one is enabled because then, the router will create a separate multicast routing table and have the necessary multicast routing entries there.
So you can see the
FF00::/8 unicast
routing table entry as a failsafe entry in the unicast routing table to prevent incorrect routing of multicast traffic in situations when the multicast routing is disabled, and the multicast traffic could be routed just like any other unicast. Thanks to this entry, the multicast traffic will be dropped rather than routed like a unicast.
At least this is how I explain that entry to myself. It's important to say that other network operating systems may behave differently. This
ff00::/8
is not a principial must, but rather a platform-and-implementation-specific thing.
Best regards,
Peter
9 Replies 9
M02@rt37
Hello @PrimeYeti,
If the router has a
FF00::/8 Null0
route configured, it would indeed block IPv6 multicast traffic, preventing NDP from functioning correctly. As a result, devices on the network won't be able to perform address resolution, leading to communication failures and other IPv6-related problems.
If you need to filter specific multicast groups or control multicast traffic in your network, more targeted and specific filtering mechanisms should be employed.
Best regards
Thanks for the reply! What is the point in this rule being added then? It seems very counterproductive. It's like, "ok cool I've just enabled IPv6 routing, but I still can't use it because my router has created a rule that stops me from using a fundamental process that allows IPv6 routing to function".
Even if I were to create an ACL that allows traffic to FF02, it doesn't seem like this would work still.
Hello @PrimeYeti,
The
FF00::/8 Null0
The
FF00::/8
FF02::/16
represents the
Best regards
Oh that could be my misinterpretation then. I was watching a Jeremy's IT Labs video to study for the CCNA and in one of the IPv6 videos he mentioned that
FF00::/8
was added automatically. Unsure if he may have misspoken because from my, albeit limited knowledge, this would cause massive issues.
I'll test for myself anyway. Thanks very much!
FF00::/8
IOS/IOS XE
unicast
So you can see the
FF00::/8 unicast
ff00::/8
Best regards,
Peter
Hi Peter,
I wasn't aware there were separate routing tables for
multicast and unicast
that is very useful to know. Thank you!
Kind regards,
Connor
@PrimeYeti share video I want to more check.
MHM
PrimeYeti
Hi Both,
I have just tested this myself and I can replicate it...? This is straight after entering the
ipv6 unicast-routing
command on a brand new router. Literally nothing else.
Link to the video is here
 Jeremy  not wrong' but this need some search to know why router add it automatically'
I Will update you about why soon
MHM
