file size large tftp does not support(IOS upgrade error)
san_dec21
Hi,all
Thanks in advance
When we are upgrade the IOS of router with latest ios which is 35 mb size file by using cisco tftp or any third party tftp software it's showing error like below
file size large.does not suuported by tftp protocol.
Danilo Dy
Use 3COM Daemon V2.0 Rev 10
http://support.3com.com/software/utilities_for_windows_32_bit.htm
Dandy
sandeep
I have used 3Cdaemon suggested by Dandy with good success. As an alternative I have heard good things about tftpd32 and its support for features like large file size. It is available from:
http://tftpd32.jounin.net/
I would also like to make the suggestion that as file sizes of IOS get larger there are benefits from using FTP instead of TFTP. Not only does FTP not have a file size restriction but the performance of FTP for transferring large files is much better than the performance of TFTP.
Rick
Rick
". . . the performance of FTP for transferring large files is much better than the performance of TFTP."
Very, very true as latency increases, as you often see on WAN links. (NB: RCP also works well too.)
I agree with Joseph. I would rather use FTP when the file size goes beyond 32 MB.
