FileSystem erros
Cassio Cruz
Hi everyone im Cassio Cruz and i've this router 2811 when boot after a fews minutes this message show up and the system crash
I need help i;ve no idea to do pls...
SDRAM ECC Error,
err addr - 0x99737C0F, err data_l 0x45B93A6D,err data_h 0x0A080101,
rcv ecc - 0xEA000000, calc ecc 0x33000000, err cnt 0x01000000
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 34 r4 = 0
r5 = 1 r6 = 0 r7 = 1080 r8 = 0 r9 = 42
r10 = 0 r11 = 0 r12 = 0 r13 = 460EF090 r14 = 0
r15 = 34 r16 = FFFFFFFF r17 = FFFFFFFE r18 = 0 r19 = 4617651E
r20 = 0 r21 = 6 r22 = 0 r23 = 4606CAF0 r24 = 0
r25 = 45FA057C r26 = 0 r27 = 4606CB40 r28 = 0 r29 = 4606CB3C
r30 = 0 r31 = 45FA057C r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = 4606CA20
r50 = 0 r51 = 0 r52 = 0 r53 = 0 r54 = 0
r55 = 0 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 4606CC60
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 4006A020
sreg = 3400F903 mdlo_hi = 0 mdlo = 0
mdhi_hi = 0 mdhi = 4E badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 40082900 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages (10:24:43 UTC Tue Aug 3 2021) ===
Queued messages:
10:24:43 UTC Tue Aug 3 2021: Interrupt exception, CPU signal 22, PC = 0x0
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback=
$0 : 00000000, AT : 00000000, v0 : 00000000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 00000000, s2 : 00000000, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 00000000, sp : 00000000, s8 : 00000000, ra : 00000000
EPC : 00000000, ErrorEPC : 00000000, SREG : 00000000
MDLO : 00000000, MDHI : 00000000, BadVaddr : 00000000
DATA_START : 0x42F408A0
Cause 00000000 (Code 0x0): Interrupt exception
Writing crashinfo to flash:crashinfo_20210803-102444
No warm reboot Storage
*** System received a System Error ***
signal= 0x16, code= 0x0, context= 0x46064398
PC = 0x40096d7c, Cause = 0x20, Status Reg = 0x34008002
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0xcb80~
00:36:17 UTC Sat Jan 1 2000: Coprocessor Unuseable exception, CPU signal 8, PC = 0x400A05D0
-Traceback= 0x400A05D0
$0 : 00000000, AT : 456D0000, v0 : 456D0000, v1 : 00000000
a0 : 44EA0000, a1 : 456D1600, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 44EA0000, t2 : AAE60000, t3 : 00000000
t4 : 000008F0, t5 : 00000D64, t6 : 186A0000, t7 : 00000000
s0 : 456D0000, s1 : 456D1000, s2 : 00000000, s3 : 00000000
s4 : 456D0000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 45E511F8, t9 : 000061A8, k0 : 3040A801, k1 : A000F000
gp : 45431440, sp : 45EE1008, s8 : 456D0000, ra : 4009EB6C
EPC : 400A05D0, ErrorEPC : BFC0900C, SREG : 3400FF03
MDLO : 00007530, MDHI : 00000000, BadVaddr : B3037607
DATA_START : 0x42F4A960
Cause A000002C (Code 0xB): Coprocessor Unuseable exception
Leo Laohoo
@Cassio Cruz wrote:
SDRAM ECC Error
Remove the CF card and reboot the router (let it go into ROMMON).  If the same errors appear then it confirms the DRAM is dead.
in addition to Leo's remarks, I think your router is old, very old (end of sale date 2011) ? So a hardware failure is indeed likely. Since you have no warranty anymore anyways, open the chassis and try to reseat the DRAM. It looks somewhat like the picture...
