SSL VPN support on ISR4221 SEC/K9
Herman Skubic
Even after all the searchings I've made, I still have a question whether ISR4221 SEC/K9 supports SSL VPN (aka webvpn)
or not?
From what I found out only ASA's have SSL VPN support, but I also found that it is expected to have SSL VPN supported on ISR4000 as well.
Herman
balaji.bandi
I do not believe it support on ISR 4K Platform, By saying that you can use AnyConnect client  for IKEv2/IPSec VPN connectivity
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
BB
crakchakib
