filter advertise default route form multiple site in EIGRP domain
Cloudy
how to filtering advertise default route form multiple site .we have site A - D and my site as a transit site in EIGRP in same AS . each site do the redistribute static default route to eigrp. in this case i see the  default route each site as a exit point.
if i want to filter default route form Site A to advertise only to Site D not sure if i can do it?. now side D see default route was advertised from Site A B and C via my SITE
because if i filter 0.0.0.0 all default route has been deny
        |--> SITE A
        |--> SITE B
HUB |
        |--> SITE C
        |--> SITE D
pieterh
there are many "solved" posts to be found.
one of these here
-> filtering inbound  and add the interface on the distribute-list in command.
if i  filtering inbound  all default route will be deny
if i use "distribute-list in" with specify interface the default route form filtered interface will deny too.
now i use solution by change AD of candidate default route.
ulrickfr2001
Can you explain what you mean by saying :
"if i want to filter default route form Site A to advertise only to Site D not sure if i can do it?. now side D see default route was advertised from Site A B and C via my SITE"
