filter traffic from lan to use different wan circuits
JATINDER KUMAR
Dear friends..
i have few lines to be exact 3 lines coming on one router i want my LAN users (Single Subnet) .. few to use one circuit to go to wan .. other to use second circuit and rest to use the the thirr or may be in future again divided into forth or fifth circuit ..
dont know if this can be possible via PBR .. please advice with some configuration guidance .. how can i achive this .. thanks for the time and help
11 Replies 11
jigardavenm
ip route 192.168.10.0 0.0.0.255 10.10.10.1 ---- lets say your subnet 1 users will go to 10.10.10.1
ip route 192.168.100.0 0.0.0.255 20.20.20.1 ---- lets say your subnet 2 users will go to 20.20.20.1
ip route 192.168.200.0 0.0.0.255 30.30.30.1 ---- lets say your subnet 3 users will go to 30.30.30.1
jigar sir .. read my post ... its a single lan subnet ... three wan lines ..
its depend,
tell me, the three connection are puted in the same router or in different router,
i must have more information,
or if you can post a picture of your architecture
.. nice question .. all three lines on same router .. and my setup is already explained on thread start..
    PBR is good to go for load-sharing. If NAT is there, you may need to read the document below.
Ref: http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
HTH,
Toshi
satya mothukuri
1st you have to div your singe network into 3 subnets.
then for ex if your network is 10.126.251.X
access-list 100 deny   ip 10.126.251.0 0.0.0.A any
access-list 100 deny   ip 10.126.251.0 0.0.0.B any
access-list 100 permit ip any any
access-list 101 deny   ip 10.126.251.0 0.0.0.C any
access-list 101 deny   ip 10.126.251.0 0.0.0.B any
access-list 101 permit ip any any
access-list 102 deny   ip 10.126.251.0 0.0.0.A any
access-list 102 deny   ip 10.126.251.0 0.0.0.C any
access-list 102 permit ip any any
route-map test permit 10
match ip address 100
set ip next-hop (To router 1)
route-map test permit 20
match ip address 101
set ip next-hop (To router 2)
match ip address 102
set ip next-hop (To router 3)
interface lan.
ip policy route-map test
hope it works
Satya.M
Hi Jatinder,
You can go with PBR, with this you can shape the traffic in which way you want.
See the below example config may helps you.
ip accesslist ext 150
permit 192.168.2.0 0.0.0.255 any
deny any any
ip accesslist ext 151
permit 192.168.3.0 0.0.0.255 any
deny any any
ip accesslist ext 152
permit 192.168.4.0 0.0.0.255 any
deny any any
route-map WAN1 permit 10
match ip address 150
route-map WAN2 permit 10
match ip address 151
route-map WAN3 permit 10
match ip address 152
interface 1provider
ip policy route-map WAN1
interface 2provider
ip policy route-map WAN2
interface 3provider
ip policy route-map WAN3
Please rate the helpfull posts.
Naidu.
guys guys... i thnk we are missing something .. i cant change my lan subnet .. i need to keep all of them in one subnet.. please advice if this is possible or not ..
Not Possibel.
Satya.M
Jatinder, I think you need to read some CCNP related books and try to search this one on internet. if you find anything that is doable the way you want, we are happy to get it informed by you in future.
sorry for my late i was in travel;
i think the best way is to do 3 nat session ;
example with 4 eth ( 3 wan e0 to e2 and 1 inside e3)
you must creat 3 acl with fragment of your lan example
acces-list 1
acces-list 2
acces-list 3
and after configure the 3 wan interface with ip nat outside
inte fas eth 0 -2
ip nat outside
and
inte fas eth 3
ip nat inside
after with acces list do different session on nat
ip nat inside source list 1 interface Ethernet 0 overload
ip nat inside source list 2 interface Ethernet 1 overload
ip nat inside source list 3 interface Ethernet 2 overload
i thik its work very good.
regards
