filtering a range of RTs by use of expanded extended community
gristanovic
I am trying to test a configuration that uses expanded extended community lists, the aim of the config is to block out a range of RTs.
The range I need blocked is from RT
I was planning to use an expanded extended list and a route map, a route map applied inbound on a bgp router (this router is a border router and my aim is to block the routes as they arrive from the far end bgp peer).
I have configured following, but no luck
ip extcommunity-list 155 deny ^RT:xxxx:[0-9]{1,7}$
route-map Gordana-inbound-to-uk deny 10
match extcommunity 155
The above route map applied on ebgp neighbour inbound
I have tested the regex in an on line regex test tool with relevant test RTs (i.e all numbers below 10000000 , RTs that have 7 digits were false as required)
My production routes wil have a number of RTs attached, e.g example test route below
65516-BGP-BR-1#show ip bgp vpnv4 rd xxxx:1880 4.4.4.4
BGP routing table entry for xxxx:1880:4.4.4.4/32, version 16620786
Paths: (2 available, best #1, table NULL)
  Advertised to non peer-group peers:
  x.x.x.x
  Local
    x.x.x.x (metric 31410) from x.x.x.x
      Origin IGP, localpref 100, valid, confed-internal, best
      Extended Community: RT:xxxx:5 RT:xxxx:666 RT:xxxx:18800 RT:xxxx:20000115
      Originator: x.x.x.x, Cluster list: x.x.x.x
  Local
      Originator: x.x.x.x, Cluster list: x.x.x.x, x.x.x.x
65516-BGP-BR-1
So in summary my questions are
1) is the above regex correct for blocking out a range of RTs from say RT:xxxx:0 to RT:xxxx:9999999
2) are you aware of any show ip bgp vpnv4 command i can use to confirm that the above community list sytax is correct?
3) regardinf use of extended community list in a route map, in order to deny a route, do I need to use deny in both community list and route map, i tried a number of permutations but no change.  I have also tried a number of permutations of regex, i.e. with letters "RT:" included , with and without ^ and $ but no luck.
Thanks.
Gordana
Harold Ritter
Hi Gordana,
1. The syntax {n,m} is actually not supported by IOS. You could meet the requirement with an extended community list similar to this:
ip extcommunity-list 155 permit ^RT:1:[0-9][0-9]?[0-9]?[0-9]?[0-9]?[0-9]?[0-9]?$
2. "show bgp vpnv4 unicast all extcommunity-list xxx" can help you with this.
3. To meet the requirement, you need to permit in the extcommunity-list and deny in the route-map
route-map test deny 10
route-map test permit 20
