Filtering EIGRP on a particular interface on Nexus 9000
Cormac Champion
I'm joining two networks together, both of which run EIGRP and both using the same AS number.  I want to filter the routes coming into Network B from Network A.  They are currently interconnected and have static routes on either side.
I can obviously create a Prefix-List and Route-Map but can I apply this to a particular interface (which would be the preferable option), or would I need to create a separate EIGRP neighbourship with a different AS number and then filter the routes being passed between AS numbers ?
Julio E. Moisa
I don't have a lot of experience with Nexus but have you tried with Distribute List? The sintaxis in other images is for example:
Router Eigrp 100
Distribute-list <ACL/Prefix-List> out FastEthernet 0/0
ACL/Prefix List will match the prefixes to be advertised only.
Out the direction of the advertising
Fast Ethernet 0/0 is the outgoing interface.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
