Find appropriate cisco router
askinzeynep
Specifications
Ports: min 2 x 1000 BaseT Ethernet + 1 x 1000BaseLX port and minimum 6 extension slots
Protocols supported : HSRP or VRRP
Support Ethernet, fast Ethernet (100FX, 100TX), gigabit Ethernet, Synchron serial , E1, E3, STM1, channelised E1; ATM (34, 155Mbps) ports.
Statefull Firewall, GRE (Generic Router Encapsulation), NAT and PAT support
Routing capacity of 2 Million pps.
Hardware support of IPSEC and 3DES performance should be no less than 800 Mbps with concurrent tunnel support of 1000 VPN tunnel.
Collin Clark
check the attached pdf which will be helpful for you.
Pravin
Thank you for helping. I think cisco 7200VXR NPE-G2 model best suitable for me.
