Find ip address of connected device
svetoslav141
I have to find the ip of a switch that is connected to an ISR.
How can I find this ip? Right now I only have the IP if the ISR and i can only log into the ISR but i need to log into the switch.
The connection between the 2 devices is with trunk on the switch.
Hello
If this the case then i assume the interface on the ISR has sub-interfaces correct?
ISR
sh arp <interface>x/x.y
sh cdp neighbor <interface> detail | in IP
Kind Regards
Paul
10 Replies 10
Hello
ISR
Kind Regards
Paul
Thank you for  the provided information it was very useful.
Seb Rupik
Hi there,
Assuming the switch has an IP in a mangment VLAN and that VLAN is part of the trunk link, check the mac-address table on the ISE filtering for both the VLAN and the interface:
sh mac-address vlan <management_vlan_id> | inc <interface>
Now assuming your ISR has an IP in the management VLAN, you can then check its ARP cache and filter on the MAC address:
sh ip arp | inc <mac_address_from_previous_step>
cheers,
Seb.
The problem is that trere are a lost of IPs in the arp table and i can't ssh tonone of them
Hello
You should be able to filter on interface as shown, try those two commands i have posted, as for gaining ssh access you sure remote access is enabled for either ssh or telnet?
Kind Regards
Paul
As shown, filter out the layer2 address from the mac-address using VLAN and interface. Once you have the mac-address select it from the ARP cache.
All being well you can filter from 000's to just one entry.
@Seb Rupik
On a router?
Kind Regards
Paul
Ah, I am too used to play with switching modules ;)
@Seb Rupik
TBH mate it may have sw module in so its still valid
Kind Regards
Paul
Thank you for that it was really helpful.
I found the IP of the switch.
