Firepower NAT
edp-adm
I have Firepower 1120 in HA cluster and problem with NAT.
I have IP addresses (A/B/C means subnets, doesn't matter i think for explanation)
A.10 - main outside public IP **bleep**
A.9 - main gateway
B.x - additional public IPs from ISP (got 5 of them, from B.146 to B.150)
C.x - internal IPs
I need to have A.10 configured as IP of outside interface and i've done it. Routing is set to static 0.0.0.0/0 via A.9. Then I need to NAT C.x to B.x IPs, so I did "nat (vlanX, outside) source static C.2 B.149 no-proxy-arp". ACLs are correct and they doesn't matter right now, "all traffic is trusted". With this config I have no internet access on C.2 system and cannot enter system from outside using B.149 IP **bleep**.
While my outside IP was B.150 everything was working correctly.
When I connect system directly to B.146 IP **bleep** it is routing via A.9 gateway.
Is there anything more that I can configure to get it working?
