First Ping fail
nicolas.guyot
i have a problem with a cisco 857-K9 router. We can access internet but if we ping a web server, every first ping fail but all others works...
I'm very new with cisco product, how can i fix it ?
Thank you very much
15 Replies 15
andrew.prince
Level 10
Level 10
Sounds like the router is sending an ARP requests
confirm your ARP timeout values on the router - also check your default gateway config is correct.
HTH>
Thank you andrew, how can i check this ?
this router connect internet with orange by adsl in France with ip negociated.
Thank you very much
Jon Marshall
Just to add to Andrew's post -
what does your default-route look like ie.
ip route 0.0.0.0 0.0.0.0
or
If it's interface then you may well see the symptoms you are having. It would be better set to an IP address.
Jon
I can connect router by telnet but i don't know how to check this. I have made setup by wizard.
Thank you
post the output of "show ip route" and "show arp" when you telnet into the router.
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
193.253.231.0/32 is subnetted, 1 subnets
C       193.253.231.158 is directly connected, Dialer1
193.253.160.0/32 is subnetted, 1 subnets
C       193.253.160.3 is directly connected, Dialer1
C    192.168.1.0/24 is directly connected, Vlan1
S*   0.0.0.0/0 is directly connected, Dialer1
And
Protocol  Address          Age (min)  Hardware Addr   Type   Interf
Internet  192.168.1.1           149   0016.46b6.4241  ARPA   Vlan1
Internet  192.168.1.3             0   0015.5d01.fa00  ARPA   Vlan1
Internet  192.168.1.4            44   0014.c2c4.8d4c  ARPA   Vlan1
Internet  192.168.1.10          236   00e0.d80d.d125  ARPA   Vlan1
Internet  192.168.1.11            0   001f.297f.c1c4  ARPA   Vlan1
Internet  192.168.1.13            0   f4ce.4605.4512  ARPA   Vlan1
Internet  192.168.1.15            9   0015.5d01.fa02  ARPA   Vlan1
Internet  192.168.1.17            0   f4ce.4604.d15d  ARPA   Vlan1
Internet  192.168.1.18           12   0015.5d01.fa03  ARPA   Vlan1
Internet  192.168.1.19            1   68b5.99f6.bfe3  ARPA   Vlan1
Internet  192.168.1.20            1   0011.85f1.2dbb  ARPA   Vlan1
Internet  192.168.1.21            0   0015.5d01.fa04  ARPA   Vlan1
Internet  192.168.1.22          185   0c60.7662.3e19  ARPA   Vlan1
Internet  192.168.1.23            0   001c.f0f9.5606  ARPA   Vlan1
Internet  192.168.1.25          178   0023.7dc6.1912  ARPA   Vlan1
Internet  192.168.1.28            0   6431.5006.576d  ARPA   Vlan1
Internet  192.168.1.29            0   e02a.821d.93e2  ARPA   Vlan1
Internet  192.168.1.30            9   00c0.ee1e.adf1  ARPA   Vlan1
Internet  192.168.1.31          177   001e.2ae1.20c2  ARPA   Vlan1
Internet  192.168.1.33            0   6c62.6d91.7084  ARPA   Vlan1
Internet  192.168.1.38          155   001e.2ae1.22be  ARPA   Vlan1
Internet  192.168.1.39            2   000f.fe19.ec8f  ARPA   Vlan1
Internet  192.168.1.40           54   000f.fe1a.cee2  ARPA   Vlan1
Internet  192.168.1.43           11   00c0.ee1e.8a8c  ARPA   Vlan1
Internet  192.168.1.44            1   001a.4b5a.ce30  ARPA   Vlan1
Internet  192.168.1.45           14   0019.db75.0cc3  ARPA   Vlan1
Internet  192.168.1.46           55   0019.db75.0cb4  ARPA   Vlan1
Internet  192.168.1.48          193   0015.5d01.fa00  ARPA   Vlan1
Internet  192.168.1.51            0   000f.fe18.cd3f  ARPA   Vlan1
Internet  192.168.1.54          256   6c62.6d91.7016  ARPA   Vlan1
Internet  192.168.1.57          107   0023.8b3c.da3b  ARPA   Vlan1
Internet  192.168.1.58            5   0019.db76.1f74  ARPA   Vlan1
Internet  192.168.1.59            1   0023.7dc6.190a  ARPA   Vlan1
Internet  192.168.1.60            6   0023.7dc6.1918  ARPA   Vlan1
Internet  192.168.1.61            3   0023.7dc6.30e0  ARPA   Vlan1
Internet  192.168.1.62            0   6c62.6d91.7016  ARPA   Vlan1
Internet  192.168.1.64          122   001c.c4f4.ff65  ARPA   Vlan1
Internet  192.168.1.65            6   001e.0b3d.fe15  ARPA   Vlan1
Internet  192.168.1.67           80   000f.fe18.ccb1  ARPA   Vlan1
Internet  192.168.1.68           16   001e.0b3e.7d0f  ARPA   Vlan1
Internet  192.168.1.69          114   000f.fe14.e7ac  ARPA   Vlan1
Internet  192.168.1.72            5   000f.fe18.a93f  ARPA   Vlan1
Internet  192.168.1.205           9   0000.aaa2.280f  ARPA   Vlan1
Internet  192.168.1.250           0   0026.551e.34e5  ARPA   Vlan1
Internet  192.168.1.253           1   001a.4b4f.2213  ARPA   Vlan1
Internet  192.168.1.254           -   8cb6.4fbb.eeb4  ARPA   Vlan1
Thank you very much
OK - your issue is right there:-
I am to assume that you are getting your IP address from your provider via either DHCP - so you will never really know what your next hop default gateway is going to be.
What you are seeing is normal for your setup.
HTH>
If the default route points to the dialer interface then the suggestion that the problem might relate to ARP for every destination is not the problem because there is no ARP on the dialer interface.
But I do wonder if a different form of the static default route might work better.  I wonder what the result might be if the original poster would remove ip route 0.0.0.0 0.0.0.0 dialer1 and replace it with ip route 0.0.0.0 0.0.0.0 dhcp
Rick
Rick
Thank you Rick, Can you tell me the command to do this ?
Nicolas
It is a straightforward change. It would look something like this:
get into enable mode
configur term
no ip route 0.0.0.0 0.0.0.0 dialer1
end
that would return you to privilege mode command prompt. Then do some testing to verify that you still have connectivity to the Internet. If it is working, especially if it is working better than before then save the changes using the command copy running startup
It that does not work you can return to the original by dong this
configur term
no ip route 0.0.0.0 0.0.0.0 dhcp
end
Or worst case, if it is not working you can power cycle the router to return to the original setup.
Rick
Rick
Hello Rick
no luck, it does not work
here is my config
cisco#show config
Using 7156 out of 131072 bytes
version 12.4
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco
boot-start-marker
boot-end-marker
logging buffered 10000
no logging console
enable secret 5 $1$W0RC$XXXX/
no aaa new-model
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-3032259736
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3032259736
revocation-check none
rsakeypair TP-self-signed-3032259736
crypto pki certificate chain TP-self-signed-3032259736
certificate self-signed 01 nvram:IOS-Self-Sig#8.cer
dot11 syslog
no ip source-route
ip dhcp excluded-address 10.10.10.1
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT101 cuseeme
ip inspect name DEFAULT101 ftp
ip inspect name DEFAULT101 h323
ip inspect name DEFAULT101 icmp
ip inspect name DEFAULT101 rcmd
ip inspect name DEFAULT101 realaudio
ip inspect name DEFAULT101 rtsp
ip inspect name DEFAULT101 esmtp
ip inspect name DEFAULT101 sqlnet
ip inspect name DEFAULT101 streamworks
ip inspect name DEFAULT101 tftp
ip inspect name DEFAULT101 tcp
ip inspect name DEFAULT101 udp
ip inspect name DEFAULT101 vdolive
no ip bootp server
ip domain name XXX.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
username admin privilege 15 secret 5 $1$Fx33$/XXX/
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 192.168.1.254 255.255.255.0
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
interface Dialer1
description $FW_OUTSIDE$
ip address negotiated
ip access-group 104 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect DEFAULT101 out
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname fti/xxxx@fti
ppp chap password 7 xxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.3 25 interface Dialer1 25
ip nat inside source static tcp 192.168.1.3 80 interface Dialer1 80
ip nat inside source static tcp 192.168.1.3 443 interface Dialer1 443
ip nat inside source static tcp 192.168.1.3 987 interface Dialer1 987
ip nat inside source static tcp 192.168.1.250 3389 interface Dialer1 3389
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark auto generated by Cisco SDM Express firewall configuratio
n
access-list 100 remark CCP_ACL Category=1
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by Cisco SDM Express firewall configuratio
n
access-list 101 remark CCP_ACL Category=1
access-list 101 permit udp host 8.8.4.4 eq domain any
access-list 101 permit udp host 8.8.8.8 eq domain any
access-list 101 deny   ip 192.168.1.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip host 0.0.0.0 any
access-list 101 deny   ip any any
access-list 102 remark CCP_ACL Category=2
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 103 remark auto generated by Cisco SDM Express firewall configuratio
n
access-list 103 remark CCP_ACL Category=1
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by Cisco SDM Express firewall configuratio
n
access-list 104 remark CCP_ACL Category=1
access-list 104 permit tcp any any eq 3389
access-list 104 permit tcp any any eq 987
access-list 104 permit tcp any any eq 443
access-list 104 permit tcp any any eq www
access-list 104 permit tcp any any eq smtp
access-list 104 deny   ip 192.168.1.0 0.0.0.255 any
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any
dialer-list 1 protocol ip permit
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Hope you can help me
use:-
no ip route 0.0.0.0 0.0.0.0 Dialer1
interface dialer1
ppp ipcp route default
See if that works for you - REMEMEBR if it does not work, revert back to the config before you changed it.
HTH>
Thank you Andrew, but it doesn't work...
I have tried to use DHCP instead of Ip Negociated but it doesnt connect.
I think you need to talk to your provider - to see how there end is configured.
HTH>
