Static NAT
Tommy Svensson
Hi.
I have the following configuration and i want o add 2 IP addresses and map with two internal devices.
How do i configure this?
Regards Tommy Svensson
IP range between xxxxxxxxx.64 - xxxxxxxxx.79
where .64 is network address and .79 broadcast
This mapping is what i would like to accomplish
External address to devices: xxxxxxxxxx.76 and xxxxxxxxxx.77
Internal address to devices: 10.10.11.20 and 10.10.11.30
ip nat pool with_overload2 xxxxxxxx.67 xxxxxxxxxxx.67 prefix-length 28
ip nat inside source list 105 pool with_overload2 overload
ip route 0.0.0.0 0.0.0.0 xxxxxxxxxxxx.65
access-list 105 permit ip 10.10.1.0 0.0.0.255 any
access-list 105 permit ip 10.10.10.0 0.0.0.255 any
access-list 105 permit ip 10.10.11.0 0.0.0.255 any
access-list 105 permit ip 10.10.12.0 0.0.0.255 any
access-list 105 permit ip 10.10.13.0 0.0.0.255 any
access-list 105 permit ip 10.10.14.0 0.0.0.255 any
access-list 105 permit ip 10.10.15.0 0.0.0.255 any
2 Accepted Solutions
Latchum Naidu
You can do static NAT like below...
ip nat inside source static 10.10.11.20 195.59.59.76 extendable
ip nat inside source static 10.10.11.30 195.59.59.77 extendable
If you want do PAT the do like below...
ip nat inside source static tcp 10.10.11.20 80 195.59.59.76 80 extendable
Hope the above will help you...
Please rate the helpfull posts.
Naidu.
cadet alain
ip nat inside source static 10.10.11.20 xxx.xxx.xxx.76
ip nat inside source static 10.10.11.30 xxx.xxx.xxx.77
Regards.
Alain.
Latchum Naidu
Naidu.
cadet alain
Regards.
Alain.
