[First Time With Cisco] How to configure ISP connection on added module?
Don_Dude
Hello.
I need to ask how to configure Internet access from ISP and switch it to other devices.
I am add to my stock router a WAN module for optical fiber and normal RJ45 cable.
Optical fiber is connected to this WAN module - port gigabitethernet0/0/0 i think.
I will send access to internet via gigabitethernet0/0 to 48-port switch and via gigabitethernet0/1 to managment computer.
How to do it? Of course you can sugest me how IP and subnet mask is best for it, but after this first switch i will create vlans, but i don't know how too... I am still learning.
I am be very grateful for help.
5 Replies 5
below is a basic configuration for a 1921. The router serves as DHCP server, and the WAN IP address is negotiated. Possibly you have a fixed IP address from your provider...
If you want to add VLANs to your network, you need to add subinterfaces to your router's LAN interface.
version 15.2
service password-encryption
hostname 1911
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone GMT +1 0
clock summer-time GMT recurring
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
lease 7
no ipv6 cef
username cisco privilege 15 password 0 cisco
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0/0
description LAN Interface
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
description ISP Connection
ip address dhcp
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
access-list 1 permit 192.168.1.0
Leo Laohoo
H0ly sh*s!  Look at those unmanaged switches!
Hello
Looking at you topology it seems to suggest your switch is to be providing the intervlan routing for you network and the router would be used for the wan access out of site?
Or is it you wish for the router itself to perform wan access and inter-vlan routing?
Which ever option you decide will have an affect on what kind of configuration needs to be provided on the router and Mgt switch.
res
Paul
Kind Regards
Paul
Yes this router will be gateway to internet and send it to this switch and one managment computer.
Solved myself.
