Flexvpn Spoke to Spoke
Lehrling
Beginner
Beginner
Hi, everybody
I have a simple Hub and Spoke Topology (one hub and three spokes). I changed the config to accommodate a direct spoke to spoke connection with a virtual template config on each spoke and NHRP shortcut. NHRP redirect on the hub. I have spoke to spoke reachability but all the traffic still goes through the hub. No virtual Access Interface on the spokes neither. What am I missing ?
Any Help appreciated. Thanks.
Lehrling
Lehrling
Beginner
Beginner
Hi Everybody,
It has been a misconfiguration of my spoke tunnel interface going to the Hub. I checked a posting of MHM on the subject (edited 12-18-2020 01:47 PM) and saw that the
ip nhrp shorcut
command was missing in the spoke tunnel configuration going to the Hub (was not needed in Hub and Spoke configuration). After I inserted the command in the tunnel config, everything works fine. It seems to me that the command must be placed in both the tunnel interface config and the virtual template config. The spokes can communicate directly bypassing the Hub. I found out checking posts of MHM on the subject.
@ MHM : Thanks a ton again. Your contributions are GOLDEN !!!
pman
Enthusiast
Enthusiast
attached config examples:
HUB
hostname hub
crypto ikev2 authorization policy default
 pool flex-pool
 def-domain cisco.com
 route set interface
 route set access-list flex-route
crypto ikev2 profile default
 match identity remote fqdn domain cisco.com
 identity local fqdn hub.cisco.com
 authentication local rsa-sig
 authentication remote rsa-sig
 pki trustpoint CA
 aaa authorization group cert list default default
 virtual-template 1
crypto ipsec profile default
 set ikev2-profile default
interface Loopback0
 ip address 172.16.1.1 255.255.255.255
interface Ethernet0/0
 ip address 10.0.0.100 255.255.255.0
interface Virtual-Template1 type tunnel
 ip unnumbered Loopback0
 ip nhrp network-id 1
 ip nhrp redirect
 tunnel protection ipsec profile default
ip local pool flex-pool 172.16.0.1 172.16.0.254
ip access-list standard flex-route
 permit any
The following is the configuration on the first FlexVPN client:
hostname spoke1
 route set interface
 identity local fqdn spoke1.cisco.com
 pki trustpoint CA
 virtual-template 1
interface Tunnel0
 ip address negotiated
 ip nhrp shortcut virtual-template 1
 ip nhrp redirect
 tunnel source Ethernet0/0
 tunnel destination 10.0.0.100
 ip address 10.0.0.110 255.255.255.0
interface Ethernet1/0
 ip address 192.168.110.1 255.255.255.0
 ip unnumbered Tunnel0
 ip nhrp redirect
 permit 192.168.110.0 0.0.0.255
The following is the configuration on the second FlexVPN client:
hostname spoke2
 route set interface
 identity local fqdn spoke2.cisco.com
 pki trustpoint CA
 virtual-template 1
interface Tunnel0
 ip nhrp redirect
 ip address 10.0.0.120 255.255.255.0
 ip address 192.168.120.1 255.255.255.0
 ip nhrp redirect
 permit 192.168.120.0 0.0.0.255
https://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_ike2vpn/configuration/15-2mt/sec-flex-spoke.html#GUID-C52DFA6D-CF76-484E-B348-51CA0792C1AB
Lehrling
Beginner
Beginner
Hi Everybody,
ip nhrp shorcut
Recognize Your Peers
