Floating static route higher AD BGP
Bill19795_2
I am setting up a remote site to provide a backup internet circuit for outbound traffic. Everything is working from the main site by redistributing a static route and using default-information originate within BGP to my MPLS provider.
Now on the remote site I setup a static route with an AD of 250 which is higher than the AD of 20 we are getting from the main site over the MPLS network.  When the route come up BGP uses the default route from the main site and everything works fine. When I clear the BGP routes at the main site the backup site installs the static route with a higher AD. The problem is when the BGP route comes back up the static route is not getting removed. From looking at some other posts it seems that the redistributed local route is still preferred by BGP. They mentioned setting the weight to 0 in a route map which I tried but I am not getting the results of removing the static route and using the BGP route.
Remote site router config:
router bgp 65011
no synchronization
bgp log-neighbor-changes
network 12.100.1.4 mask 255.255.255.252
network 192.168.2.0
redistribute static route-map redist-static-bgp
neighbor 12.100.1.5 remote-as 1000
neighbor 12.100.1.5 send-community
neighbor 12.100.1.5 weight 40000
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.2.254 250
access-list 10 permit 0.0.0.0
access-list 10 deny   any
route-map redist-static-bgp permit 10
match ip address 10
Everything working correctly:
Gateway of last resort is 12.100.1.5 to network 0.0.0.0
     12.0.0.0/30 is subnetted, 3 subnets
B       12.100.1.0 [20/0] via 12.100.1.5, 00:00:48
C       12.100.1.4 is directly connected, Serial0/0
B       12.100.1.16 [20/0] via 12.100.1.5, 00:00:48
B    192.168.1.0/24 [20/0] via 12.100.1.5, 00:00:48
C    192.168.2.0/24 is directly connected, FastEthernet0/0
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:00:48
B*   0.0.0.0/0 [20/0] via 12.100.1.5, 00:00:48
RS1R1#show ip bgp
BGP table version is 9, local router ID is 192.168.2.253
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          12.100.1.5                         40000 1000 65010 ?
*> 12.100.1.0/30    12.100.1.5               0         40000 1000 i
r> 12.100.1.4/30    12.100.1.5               0         40000 1000 i
r                   0.0.0.0                  0         32768 i
*> 12.100.1.16/30   12.100.1.5               0         40000 1000 i
*> 192.168.1.0      12.100.1.5                         40000 1000 65010 i
*> 192.168.2.0      0.0.0.0                  0         32768 i
*> 192.168.3.0      12.100.1.5                         40000 1000 65012 i
RS1R1#
CLEAR IP BGP *  :
RS1R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.2.254 to network 0.0.0.0
B       12.100.1.0 [20/0] via 12.100.1.5, 00:03:13
B       12.100.1.16 [20/0] via 12.100.1.5, 00:03:13
B    192.168.1.0/24 [20/0] via 12.100.1.5, 00:00:12
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:03:13
S*   0.0.0.0/0 [250/0] via 192.168.2.254
RS1R1#show ip bgp
BGP table version is 13, local router ID is 192.168.2.253
*> 0.0.0.0          192.168.2.254            0         32768 ?
r                   0.0.0.0                  0         32768 i
RS1R1#
24 Replies 24
Peter Paluch
Bill,
I wonder - why do you actually redistribute the static default route into BGP on your remote site? Is that necessary for  some other routers? What you see happening seems to be some kind of a race condition: because the default route from the main site goes away,  the static backup route makes it into the routing table and  subsequently to the BGP database. Now, even when the default route from  the main site comes back, your router runs the BGP bestpath algorithm  and it decides that the locally injected route is better than the route from the main site. This is kind of strange for me because the locally  originated route is the third step in best path decision process (the  first is the weight, the second is the local preference).
Nevertheless, my primary question is that whether it is appropriate to inject the default route into BGP on the remote site at all.
Best regards,
Peter
I have several other sites that will use this backup site for Internet in the event the main site Internet is down. So in order to use default-information  I will need a static route in the routing table.
Bill,
Allright then. I have had a closer look at the outputs you have provided. What surprises me is that after you do the clear ip bgp * on your remote site, there is only one default route present in your BGP table - the one that is locally redistributed into BGP. Specifically, there is no default route learned via BGP coming from the main site.
It looks to me as if the default route injected into BGP on the remote site gets advertised to the main site, and the main site considers it better than its own default route, so it uses it and does not advertise any default route back to the remote site. In other words, the main site does not assert itself but rather submits to the remote site as soon as the remote site starts advertising its default route. I guess we also need to inspect the processes running on the main site.
What you could do as a simple test: on the main site, set the local preference of the locally redistributed default route to, say, 200, and on the remote site, set the local preference of the locally redistributed default route to 150. This should force the routers to trust the main site more than the remote site. Don't forget to clear the BGP processes after making this modification.
Best regards,
Peter
Hi Peter,
some corrections to your ideas:
1) The main site might be still advertising the default route. You don't receive it on the remote site because the BGP neighbor 12.100.1.5 is receiving the default route both from the backbone and from the remote site itself. And the prefix received from the remote site has better BGP attributes probably. So it's the 12.100.1.5 router which is not advertising the default received from the backbone (main site originally) to the remote site.
2) Local preference tuning will not help here. Local preference attribute is used only within the local AS, not advertised via eBGP. As the main and remote sites are within different ASes, it will not work.
3) IMHO, what's necessary here, is:
a) Setting the weight to 0 when redistributing  the static default route to BGP on the remote site. (Locally originated prefixes are getting the weight 32768 by default. That's why the default route redistributed from static always beats the default route received from the backbone.)
b) Also setting local preference to 50 (or anything lower than the default 100) for the static default route redistributed to BGP.
This will make the default coming from the backbone to win.
c) Prepend the remote site AS number several times to the default route when advertising it to the eBGP neighbor.
When some third site (or even the 12.100.1.5 neighbor) receives the default route both from the main site and from the remote site, the longer AS_PATH created by prepending will make the default route originated from remote site less preferred.
HTH,
Milan
Hi Milan,
Thank you for replying!
I guess that is exactly what I am saying, just probably I did not select the proper words for it. Perhaps a misunderstanding In any case, the remote site does not receive the default route from the main site, suggesting that the bestpath on main site still points towards the remote site, that's why it is not advertised back. We should definitely see the default route in the BGP database, advertised from the main site.
Absolutely correct - I have overlooked that the two BGP speakers are in different autonomous systems. Thank you for pointing that out! Shame on me
I guess I am little at a loss in understanding the entire BGP setup in this case and the different locations interact with each other. Perhaps a brief exhibit showing the individual locations and the flow of routing information would be helpful.
Best regards,
Peter
Hi Peter,
the topology used here is probably very similar to our enterprise network.
IMHO, it's important to understand the topology is quite complex:
As there is a provider MPLS backbone, there's probably a provider CE router on each site peering via eBGP with the customer router.
And also peering to provider PE router (backbone).
So on the main site, the customer router can still be using it's static default route as the best and advertise it to the provider.
On the remote site, the provider CE router (12.100.1.5 in our case) is receiving the default route via BGP from the remote  PE router and also from the remote site customer router. And as the prefix received with shorter AS-PATH from the remote sites wins on the provider remote CE router.
I hope to be clearer now?
BR,
Milan
Here is a diagram of the network. The goal is to provide backup outbound Internet only in the event the Internet at the HQ site is down.
so if the config you showed in the original post is still valid, you IMHO need to add to your RS1R1 config:
ip as-path access-list 1 permit ^$
match ip address 10
set weight 0
set local-preference 50
route-map prep-default out permit 10
match ip address 10
match as-path 1
set as-path prepend  65011 65011 65011 65011 65011
route-map prep-default out permit 20
router bgp 65011
neighbor  12.100.1.5 route-map prep-default out
After the config change, don't forget to apply
clear ip bgp * soft
HTH,
Milan
Thanks for your help Milan.
This sort of works. Sometimes the static route will be removed at the remote site and sometimes it will not.
Remote site configuration:
router bgp 65011
no synchronization
network 192.168.2.0
no auto-summary
ip http server
no ip http secure-server
access-list 20 permit 0.0.0.0
access-list 20 deny   any
route-map redist-eigrp-bgp permit 10
match ip address 20
route-map prep-default permit 10
match ip address 10
match as-path 1
route-map prep-default permit 20
match ip address 10
set weight 0
Remote site when everything is working as desired:
RS1R1#show ip route
B       12.100.1.0 [20/0] via 12.100.1.5, 00:03:43
B       12.100.1.16 [20/0] via 12.100.1.5, 00:03:43
B    192.168.1.0/24 [20/0] via 12.100.1.5, 00:03:43
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:03:43
B*   0.0.0.0/0 [20/0] via 12.100.1.5, 00:03:43
RS1R1#show ip bgp
r                   0.0.0.0                  0         32768 i
RS1R1#
Shutdown HQ serial interface. Remote site routes:
RS1R1#show ip route
     12.0.0.0/30 is subnetted, 2 subnets
B       12.100.1.16 [20/0] via 12.100.1.5, 00:07:05
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:07:05
RS1R1#show ip bgp
*> 0.0.0.0          192.168.2.254            0     50      0 ?
r                   0.0.0.0                  0         32768 i
RS1R1#
First time to bring HQ Serial back up. 192.168.1.x route is added. Remote site routes:
RS1R1#show ip route
B       12.100.1.0 [20/0] via 12.100.1.5, 00:01:00
B       12.100.1.16 [20/0] via 12.100.1.5, 00:09:15
B    192.168.1.0/24 [20/0] via 12.100.1.5, 00:00:20
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:09:15
B*   0.0.0.0/0 [20/0] via 12.100.1.5, 00:00:20
RS1R1#
RS1R1#
RS1R1#show ip bgp
BGP table version is 16, local router ID is 192.168.2.253
r                   0.0.0.0                  0         32768 i
RS1R1#
Shutdown HQ site again. Routes get deleted:
RS1R1#show ip route
B       12.100.1.16 [20/0] via 12.100.1.5, 00:10:57
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:10:57
RS1R1#show ip bgp
BGP table version is 20, local router ID is 192.168.2.253
r                   0.0.0.0                  0         32768 i
RS1R1#
Bring HQ serial back up. Default route does not get removed:
RS1R1#show ip route
B       12.100.1.0 [20/0] via 12.100.1.5, 00:00:55
B       12.100.1.16 [20/0] via 12.100.1.5, 00:12:42
B    192.168.1.0/24 [20/0] via 12.100.1.5, 00:00:17
B    192.168.3.0/24 [20/0] via 12.100.1.5, 00:12:42
RS1R1#show ip bgp
BGP table version is 22, local router ID is 192.168.2.253
r                   0.0.0.0                  0         32768 i
RS1R1#
Do you think this is some type of bug?
IMHO, it should be working. There might be route dampening of some other default route source bringing trouble, e.g.
It would be good to check at the moment it failed:
a) Is your main site still advertising the default route to the backbone?
b) Is the provider router 12.100.1.5 receiving the default route from the main site?
If yes, is it the best one?
BR,
Milan
So it did start working after I verifed my configuration and restrted everything.
We are almost there. Now my problem is when I bounce the HQ connection everything works fine. When I use IP SLA at the HQ site it removes the route when the firewall is down and everything works as expected. I bring the firewall back up and the IP SLA puts the route back in but the BGP does not get updated. It's like the SLA does not trigger a routing update to the BGP peer.
It seems as if the MPLS router never gets the update once the HQ router puts the default route back into it's routing table. The MPLS router never changes it's route from the RS1 router as it's gateway of last resort.
are you talking about your HQ MPLS router?
How does the IP SLA configuration look like on your HQ router in details?
BR,
Milan
track 1 rtr 1 reachability
router bgp 65010
no synchronization
network 12.100.1.0 mask 255.255.255.252
network 192.168.1.0
redistribute eigrp 100 route-map redist-eigrp-bgp
neighbor 12.100.1.1 remote-as 1000
neighbor 12.100.1.1 weight 40000
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.1.254 track 1
ip http server
ip sla 1
icmp-echo 192.168.1.254 source-interface FastEthernet0/0
timeout 1000
frequency 3
ip sla schedule 1 life forever start-time now
match ip address 20
set metric 10
match ip address 10
HQR1#show ip route
Gateway of last resort is 192.168.1.254 to network 0.0.0.0
C       12.100.1.0 is directly connected, Serial0/0
B       12.100.1.4 [20/0] via 12.100.1.1, 14:09:56
C    192.168.1.0/24 is directly connected, FastEthernet0/0
B    192.168.2.0/24 [20/0] via 12.100.1.1, 14:09:56
S*   0.0.0.0/0 [1/0] via 192.168.1.254
HQR1#
Shutdown interface with 192.168.1.254
HQR1#
HQR1#show ip route
Gateway of last resort is 12.100.1.1 to network 0.0.0.0
B       12.100.1.4 [20/0] via 12.100.1.1, 14:13:42
B    192.168.2.0/24 [20/0] via 12.100.1.1, 14:13:42
B*   0.0.0.0/0 [20/0] via 12.100.1.1, 00:00:01
HQR1#
Bring interface back up:
HQR1#show ip route
B       12.100.1.4 [20/0] via 12.100.1.1, 14:14:08
B    192.168.2.0/24 [20/0] via 12.100.1.1, 14:14:08
