BGP Routing question
Steven Peterson
I am trying to set up a new router for training.
I am attempting to my First BGP multihome.
The router is a 2921.
We have a bonded t1 line and a metro ethernet connection
we have 2 /24 networks 1 /23 and 1 ipv6 /48
Behind the cisco router we have 3 Open BSD firewall Pairs, that are used to segment the networks into the production, development and my lab.
one of the /24 and the ipv6 block are veriably subneted, these are the routes that I am having troubles with.
I am attempting to aggregrate the /24 and the ipv6 block to go out to the internet.
they show up in the routing table as advertised but you can not reach any hosts through the cisco router.
Any ideas on this would be greatly appriciated.
here is the bgp config
address-family ipv4
  network 24.104.xxx.240 mask 255.255.255.240
  network 204.17.xxx.0 mask 255.255.254.0
  network 204.138.xxx.0
  network 192.231.xxx.0
  aggregate-address 204.138.167.0 255.255.255.0 as-set summary-only
  redistribute static route-map rm_redist_ok
  neighbor 24.104.64.105 activate
  neighbor 24.104.64.105 remove-private-as
  neighbor 24.104.64.105 soft-reconfiguration inbound
  neighbor 24.104.64.105 route-map rm_peer_1_in in
  neighbor 24.104.64.105 route-map rm_peer_1_out out
  no neighbor 2001:559:0:80::11 activate
  neighbor 64.223.133.37 soft-reconfiguration inbound
  neighbor 64.223.133.37 route-map rm_peer_2_in in
  neighbor 64.223.133.37 route-map rm_peer_2_out out
  no auto-summary
exit-address-family
address-family ipv6
  redistribute static route-map ipv6_redist_ok
  network 2620:xx::/48
  aggregate-address 2620:17::/48 as-set summary-only
  neighbor 2001:559:0:80::11 remove-private-as
  neighbor 2001:559:0:80::11 route-map rm_peer_1_in in
  neighbor 2001:559:0:80::11 route-map rm_peer_1_out out
exit-address-family
My static routes
ip route 64.223.xxx.64 255.255.255.240 204.138.xxx.140 10 name Pro-gate
ip route 192.231.xxx.0 255.255.255.0 204.138.xxx.160 10 name Dev-Gate
ip route 204.17.xxx.0 255.255.254.0 204.138.xxx.160 10 name Dev-Gate
ip route 204.138.xxx.0 255.255.255.128 204.138.xxx.140 10 name Pro-Gate
ip route 204.138.xxx.192 255.255.255.192 204.138.xxx.170 10 name Lab-Gate
IPv6 static routes Currently all point to the lab
ipv6 route 2620:xx:0:1A00::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A01::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A02::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A03::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A04::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A0A::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A0B::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A0C::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A0D::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A0E::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
ipv6 route 2620:xx:0:1A0F::/64 2620:xx:0:1B00:59AE:3D27:C74C:9525 10
Hi Steven,
Is it possible for you to paste in "sh ip bgp" and also the route-maps config
Here are the route map configs, My ISP is giving us full internet routes so the out put of sh ip bgp is over 32 mb, just a bit big for a forum posting
in its lew I have inclded the output of sh ip bgp neighbors, and the routes advertised.
BGP neighbor is 24.104.64.105,  remote AS 7922, external link
Description: Comcast
  BGP version 4, remote router ID 68.86.1.67
  BGP state = Established, up for 3d16h
  Last read 00:00:00, last write 00:00:42, hold time is 180, keepalive interval is 60 seconds
  Neighbor sessions:
    1 active, is multisession capable
  Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised
    Address family IPv4 Unicast: advertised and received
    Graceful Restart Capability: received
      Remote Restart timer is 120 seconds
      Address families advertised by peer:
        IPv4 Unicast (was not preserved)
    Multisession Capability: advertised and received
  Message statistics, state Established:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:               13     456462
    Keepalives:          5820          9
    Route Refresh:          0          0
    Total:               5834     456472
  Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
  Session: 24.104.64.105 session 1
  BGP table version 1760862, neighbor version 1760862/0
  Output queue size : 0
  Index 4
  4 update-group member
  Inbound soft reconfiguration allowed
  Private AS number removed from updates to this neighbor
  Inbound path policy configured
  Outbound path policy configured
  Route map for incoming advertisements is rm_peer_1_in
  Route map for outgoing advertisements is rm_peer_1_out
  Slow-peer detection is disabled
  Slow-peer split-update-group dynamic is disabled
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:               3     342510 (Consumes 35621040 bytes)
    Prefixes Total:                11    1798323
    Implicit Withdraw:              6    1387299
    Explicit Withdraw:              2      68514
    Used as bestpath:             n/a     342510
    Used as multipath:            n/a          0
    Saved (soft-reconfig):        n/a     342510 (Consumes 17810520 bytes)
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    AS_PATH loop:                       n/a          5
    Bestpath from this peer:              6        n/a
    Suppressed due to dampening:          6        n/a
    Invalid Path:                     68517        n/a
    Other Policies:                 2376293        n/a
    Total:                          2444822          5
  Number of NLRIs in the update sent: max 2, min 0
  Last detected as dynamic slow peer: never
  Dynamic slow peer recovered: never
  Address tracking is enabled, the RIB does have a route to 24.104.64.105
  Connections established 4; dropped 3
  Last reset 3d16h, due to Peer closed the session
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: 24.104.64.106, Local port: 49233
Foreign host: 24.104.64.105, Foreign port: 179
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x189B9D64):
Timer          Starts    Wakeups            Next
Retrans          5833          0             0x0
TimeWait            0          0             0x0
AckHold         94095      73982             0x0
SendWnd             0          0             0x0
KeepAlive           0          0             0x0
GiveUp              0          0             0x0
PmtuAger       484114     484113      0x189B9F3D
DeadWait            0          0             0x0
Linger              0          0             0x0
ProcessQ            0          0             0x0
iss: 2854086735  snduna: 2854198028  sndnxt: 2854198028
irs: 4170065237  rcvnxt: 4209371521
sndwnd:  16327  scale:      0  maxrcvwnd:  16384
rcvwnd:  15330  scale:      0  delrcvwnd:   1054
SRTT: 650 ms, RTTO: 653 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 4 ms, maxRTT: 650 ms, ACK hold: 200 ms
Status Flags: active open
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 107177 (out of order: 0), with data: 101195, total data bytes: 39306283
Sent: 103620 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 5833, total data bytes: 111292
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
BGP table version is 1761515, local router ID is 24.104.64.106
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 24.104.xxx.240/28
                    0.0.0.0                  0         32768 i
*> 204.17.xxx.0/23  204.138.xxx.160          0         32768 i
*> 204.138.xxx.0    0.0.0.0                            32768 i
Total number of prefixes 3
route-map rm_redist_ok permit 10
match ip address 1301
route-map rm_peer_1_out permit 5
match ip address prefix-list pl_peer_1_out
match ipv6 address prefix-list pl_peer_1_out
set as-path prepend 16434
route-map rm_peer_2_out permit 5
route-map ipv6_redist_ok permit 10
match policy-list ipv6_redist
route-map rm_peer_1_in permit 5
set local-preference 150
route-map rm_peer_2_in permit 5
set local-preference 50
ipv6 access-list ipv6_redist
permit ipv6 2620:xx::/48 any
ip prefix-list pl_peer_1_in seq 5 deny 10.0.0.0/8
ip prefix-list pl_peer_1_in seq 10 deny 172.16.0.0/12
ip prefix-list pl_peer_1_in seq 15 deny 192.168.0.0/16
ip prefix-list pl_peer_1_in seq 20 deny 169.254.0.0/16
ip prefix-list pl_peer_1_in seq 25 deny 0.0.0.0/8
ip prefix-list pl_peer_1_in seq 30 deny 127.0.0.0/8
ip prefix-list pl_peer_1_in seq 35 deny 198.18.0.0/15
ip prefix-list pl_peer_1_in seq 40 deny 192.0.2.0/24
ip prefix-list pl_peer_1_in seq 45 deny 198.51.100.0/24
ip prefix-list pl_peer_1_in seq 50 deny 203.0.113.0/24
ip prefix-list pl_peer_1_in seq 55 permit 0.0.0.0/0
ip prefix-list pl_peer_1_out seq 5 permit 204.17.xxx.0/23
ip prefix-list pl_peer_1_out seq 10 permit 192.231.xxx.0/24
ip prefix-list pl_peer_1_out seq 15 permit 204.138.xxx.0/24
ip prefix-list pl_peer_1_out seq 20 permit 24.104.xxx.240/28
ip prefix-list pl_peer_2_in seq 5 deny 10.0.0.0/8
ip prefix-list pl_peer_2_in seq 10 deny 172.16.0.0/12
ip prefix-list pl_peer_2_in seq 15 deny 192.168.0.0/16
ip prefix-list pl_peer_2_in seq 20 deny 169.254.0.0/16
ip prefix-list pl_peer_2_in seq 25 deny 0.0.0.0/8
ip prefix-list pl_peer_2_in seq 30 deny 127.0.0.0/8
ip prefix-list pl_peer_2_in seq 35 deny 198.18.0.0/15
ip prefix-list pl_peer_2_in seq 40 deny 192.0.2.0/24
ip prefix-list pl_peer_2_in seq 45 deny 198.51.100.0/24
ip prefix-list pl_peer_2_in seq 50 deny 203.0.113.0/24
ip prefix-list pl_peer_2_in seq 55 permit 0.0.0.0/0
ip prefix-list pl_peer_2_out seq 5 permit 204.17.xxx.0/23
ip prefix-list pl_peer_2_out seq 10 permit 192.231.xxx.0/24
ip prefix-list pl_peer_2_out seq 15 permit 204.138.xxx.0/24
ip prefix-list pl_peer_2_out seq 20 permit 24.104.xxx.240/28
