02-20-2012 11:11 PM - edited 03-04-2019 03:21 PM
Guys,
I have a Cisco 1841 with a DSL and 3G HWIC interface. I would like to setup the DSL as the primary link and then use the 3G as a backup interface. I am trying to accomplish this using the Floating Static routes with SLA object tracking.
I have tried various options, like having two tracked routes, one tracked route, changing administrative distances, multiple SLA's, etc etc.
My problem basically is that when the DSL (Dialer0) goes down and the 3G (Cellular0/1/0) takes over, that the SLA never changes back when the DSL is available again, so that the DSL can take over as the primary link again.
My current config:
version 12.4
hostname router_hostname
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging buffered
no aaa new-model
dot11 syslog
ip source-route
no ip cef
ip domain name dyndns.org
ip ddns update method ccp_ddns1
! my_dyndns_details
no ipv6 cef
chat-script gsm "" "ATDT*99*1#" TIMEOUT 60 "CONNECT"
track 1 ip sla 1 reachability
track 2 list boolean and
object 1 not
interface Loopback0
ip address 50.35.8.1 255.255.255.255
interface FastEthernet0/0
description $ETH-LAN$
ip address 40.35.8.1 255.255.255.128
ip tcp adjust-mss 1412
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface Cellular0/1/0
ip address negotiated
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
ppp chap hostname uid
ppp chap password 0 pwd
ppp ipcp dns request
interface Dialer0
ip ddns update ccp_ddns1
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname my_hostname
ppp chap password 0 m_password
ppp pap sent-username my_hostname password 0 my_password
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 10 track 2
ip route 0.0.0.0 0.0.0.0 Dialer0 20 permanent
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip sla 1
icmp-echo 196.25.1.1 source-interface Dialer0
timeout 10000
threshold 55
ip sla schedule 1 life forever start-time now
dialer-list 1 protocol ip permit
control-plane
line con 0
speed 115200
line aux 0
line 0/1/0
script dialer gsm
modem InOut
no exec
transport input all
speed 384000
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
end !
version 12.4
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
dot11 syslog
ip source-route
no ip cef
! my_dyndns_details
no ipv6 cef
object 1 not
interface Loopback0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
pvc 8/35
encapsulation ppp
dialer in-band
dialer string gsm
dialer-group 1
interface Dialer0
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ip http server
ip sla 1
timeout 10000
threshold 55
control-plane
line con 0
speed 115200
line aux 0
line 0/1/0
script dialer gsm
modem InOut
no exec
transport input all
speed 384000
line vty 0 4
login local
end
02-25-2012 07:36 PM
can you help me understanding how are you testing this.
I did a similar test with 2 serials configured in same fashion with 1841 (flash:c1841c-advipservicesk9mz.150-1.M5.bin"),
it works perfectly fine.
Ambuj
02-26-2012 02:06 AM
You are removing the route for cellular when you are tracking the ATM route.
Your cellular interface should be a permanent route with the higher metric while your dialer route should have the track on it with a lower metric
02-27-2012 05:36 AM
I managed to resolve this eventually. I added a permanent static route to the IP being tested in the SLA :
ip route 196.25.1.1 255.255.255.255 Dialer0 permanent
My SLA has been working fine since then ...
