Flow control and Broadcast Storm
enandres
¿Could the flow control stop a broadcast storm?
Thx!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The flow control you have in mind is Ethernet flow control?
Doubtful.  First, the actual volume of broadcasts that might cause an issue might not be high enough to trigger flow control pauses.  Second, if it did trigger, the sender is only delayed, i.e. it will send the broadcast when it resumes its transmission.
Additionally since flow control normally pauses all transmission, it could delay other traffic.  A better solution should be usage of a broadcast storm suppression feature, if supported.
if you meant storm control. then please see the doco below. It gives you an idea to stop broadcast storm
http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/storm.pdf
