I am a service provider.
I have 2 paths to the internet.
I have a Layer 4 switch that decides which path the HTTP(80) traffic should flow.
basically i put blocks of /19,/20,/21 on the HTTP path to the internet.
Also, I have a alot of flow-redirection rules on the switch. About 48-54 on them
Always the CPU utilization is at 81-90 percent and then the switch reboots and then for 2 or 3 minutes I can see a huge dip in my internet traffic.
I then enter the switch and disable the rules and enable them back. Everything works fine from there onwards
Any suggestions??
