flow sampler
zahidlatif
Dear
I came to know that flow-sampler can be applied on inteface either egree or ingress. But we cannot assign both.
flow-export destination *.*.*.*.*
ip flow-export version 9
flow-sampler-map test
mode random one-out-of 1000
int fast 0/0
ip flow-sampler test
ip flow-sampler test  ingress
I just want to know that can we apply flow-sampler ingress and egress togehter on single interface as cisco some document says that it can two sampler cannot be applied to same interface.
santospimentel
YES ...you can....but I have other question... about disable ip flow default (no sample) below? and I need put " ip flow-export template option sampler"
int fast 0/0
no ip flow egress
no ip flow ingress
