Force tunneling Azure traffic through on-prem ASA5525
johnplizarazo
Hello, I'm looking for assistance in routing traffic from our Azure environment through our on-prem ASA5525 and then out to the internet or to other internal hosts. I currently have a VPN tunnel working, so pinging between any hosts on Azure and on-prem is successful, however when I route all Azure host's traffic (not just our on-prem subnet) to Azure's VPN gateway and then to our ASA5525, there is no internet connection on the Azure host (whereas if I leave default route to exit Azure's local internet gateway, there is internet connection).
I'm not sure what configuration change needs to be made as there is a default route on the ASA5525 to exit its outside interface. I thought that when Azure traffic would hit the ASA5525, it would route right back out the local outside interface. Am I missing something?
Any help would be appreciated, thanks!
Francesco Molino
Hi Johnplizarazo
First, I'm not very familiar with azure more aws...
Then i would ask what type of vpn do you have? Policy based vpn or route based vpn?
On route based vpn, you can add a default route going through tunnel interface.
On policy based vpn, you have to do a full tunnel which means on your crypto acl, you need to add the 0.0.0.0/0 statement.
Then for both of them, the traffic arrives on outside interface and i bet you're using the same interface to access Internet, am i right?
If so you need to allow traffic coming in and going out the same interface using the command same-security-traffic permit intra-interface. Then you'll need to nat this traffic and for this you'll need to do u-turn nat config. Afterwards, adapt your ACLs if needed to allow them accessing internet.
After these changes on your asa, you'll be able to access Internet from azure.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
